Brightsign 4k Battery Replacement
    1. Brightsign 4k Battery Replacement, Outer Shell: step 1, image 1 of 3 Brightsign 4k Battery Replacement, Outer Shell: step 1, image 2 of 3 Brightsign 4k Battery Replacement, Outer Shell: step 1, image 3 of 3
      • Remove three 8mm screws from the left side of the device.
      • Remove four 8mm screws from the right side of the device.
      Ask FixBot
    2. Brightsign 4k Battery Replacement: step 2, image 1 of 3 Brightsign 4k Battery Replacement: step 2, image 2 of 3 Brightsign 4k Battery Replacement: step 2, image 3 of 3
      • Apply pressure on the SD card to pop it out of the port.
      • Remove the card by pulling it out.
      Ask FixBot
    3. Brightsign 4k Battery Replacement: step 3, image 1 of 3 Brightsign 4k Battery Replacement: step 3, image 2 of 3 Brightsign 4k Battery Replacement: step 3, image 3 of 3
      • Press down on the top cover of the device and slid it towards you until you see a slight gap created.
      • Lift the top cover off.
      Ask FixBot
    4. Brightsign 4k Battery Replacement: step 4, image 1 of 3 Brightsign 4k Battery Replacement: step 4, image 2 of 3 Brightsign 4k Battery Replacement: step 4, image 3 of 3
      • Slide the body case back away from the bottom.
      • Pull up the body case to remove it from the bottom.
      Ask FixBot
    1. Brightsign 4k Battery Replacement, Motherboard Removal: step 5, image 1 of 2 Brightsign 4k Battery Replacement, Motherboard Removal: step 5, image 2 of 2
      • Remove the four 8mm screws at each corner of the motherboard with a JIS #0 screwdriver.
      Ask FixBot
    2. Brightsign 4k Battery Replacement: step 6, image 1 of 2 Brightsign 4k Battery Replacement: step 6, image 2 of 2
      • Lift the motherboard out of the casing.
      Ask FixBot
    1. Brightsign 4k Battery Replacement, Battery: step 7, image 1 of 2 Brightsign 4k Battery Replacement, Battery: step 7, image 2 of 2
      • Flip the motherboard over.
      • Desolder the two solder joints and remove the melted solder.
      • Beware of over heating the soldering kit will damage the logic board.
      Ask FixBot
    2. Brightsign 4k Battery Replacement: step 8, image 1 of 3 Brightsign 4k Battery Replacement: step 8, image 2 of 3 Brightsign 4k Battery Replacement: step 8, image 3 of 3
      Tool used on this step:
      Desoldering Pump
      $3.99
      Buy
      • Apply the desoldering pump to remove the melted part from the motherboard (press the button to release it).
      • Pull the battery from the motherboard.
      Ask FixBot
Tuong Ngo
85 Reputation
1 Guide authored
USF Tampa, Team S17-G6, Boczar Spring 2018 Member of USF Tampa, Team S17-G6, Boczar Spring 2018
USFT-BOCZAR-S18S17G6
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 28
All Time: 898
