Breville BKC600XL On/Off Switch Replacement
  1. Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: step 1, image 1 of 3 Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: step 1, image 2 of 3 Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: step 1, image 3 of 3
    • Use a Phillips #0 screwdriver to remove the following ten screws:
    • Four 18mm Phillips screws.
    • Four 9.75mm Phillips screws.
    • Two 8mm Phillips screws.
    • The cover will not remove entirely. Keep green ground wire attached to the cover.
    Ask FixBot
  2. Breville BKC600XL On/Off Switch Replacement, Black Water Inlet: step 2, image 1 of 2 Breville BKC600XL On/Off Switch Replacement, Black Water Inlet: step 2, image 2 of 2
    • Remove the two 14.5 Phillips screws.
    • Ensure that only the water inlet valve can be moved.
    Ask FixBot
  3. Breville BKC600XL On/Off Switch Replacement, Bottom Cover #2: step 3, image 1 of 2 Breville BKC600XL On/Off Switch Replacement, Bottom Cover #2: step 3, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the following six screws:
    • Six 14.5mm Phillips screws.
    Ask FixBot
  4. Breville BKC600XL On/Off Switch Replacement, Power Cord: step 4, image 1 of 2 Breville BKC600XL On/Off Switch Replacement, Power Cord: step 4, image 2 of 2
    • Remove the power cord from the groove. (the black cord that leads into the green wire.)
    • This creates more slack in the wire to give you more room to work with.
    • DO NOT remove green wire from the cover its attached to.
    Ask FixBot
  5. Breville BKC600XL On/Off Switch Replacement, On/Off Switch: step 5, image 1 of 1
    • Carefully pull both the red and blue wires that covered at the tip.
    • Do not yank them out from the other end. Move them aside and out of the way.
    Ask FixBot
  6. Breville BKC600XL On/Off Switch Replacement: step 6, image 1 of 1
    • Carefully remove the On/Off Switch from its slot on the outside cover.
    • The wires for the switch need to be tied back into the wires that lead to the battery. If needed, use electrical tape.
    Ask FixBot
3 other people completed this guide.
Antonio
135 Reputation
6 Guides authored
Cal Poly, Team 1-3, Propen Fall 2012 Member of Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
4 Members
24 Guides authored
3 Guide Comments
Any source for the switch?
Mark Bell - Reply Share
Thanks to this great post, I replaced my Breville BKC700XL On/Off Switch. The momentary switch is JR Products 12815 Black SPST Mini Mom-On/Off Switch, $8 on Amazon. https://www.amazon.com/dp/B002UC6QY0?psc...
Now, my Breville single serve is like new. I almost ordered a new machine, then I found ifixit. Kudos to you guys.
Boyd Gilbert - Reply Share
This repair worked like a charm! Boyd Gilberts part number link was perfect....coffee machine is running great once again.
anthonypetric112 - Reply Share
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 61
All Time: 4,588
