Brentwood TS-292B Power Cable Replacement
  1. Brentwood TS-292B Power Cable Replacement, Power Cable: step 1, image 1 of 1
    • Remove the five 6mm screws on the bottom of the toaster with a Phillips #2 screw driver.
    Ask FixBot
  2. Brentwood TS-292B Power Cable Replacement: step 2, image 1 of 1
    • To remove the toasting lever, pull the lever away from the toaster.
    Ask FixBot
  3. Brentwood TS-292B Power Cable Replacement: step 3, image 1 of 1
    • Unplug the wire connecting the casing to the circuit board to fully remove the toaster casing.
    Ask FixBot
  4. Brentwood TS-292B Power Cable Replacement: step 4, image 1 of 1
    • Unscrew the wire bracket with a Phillips #2 screw driver.
    Ask FixBot
  5. Brentwood TS-292B Power Cable Replacement: step 5, image 1 of 1
    • Pull back on the black tab that is holding the circuit board in place.
    • While pulling the tab back, lift up on the circuit board.
    Ask FixBot
  6. Brentwood TS-292B Power Cable Replacement: step 6, image 1 of 1
    • Desolder the power wire connections on the circuit board.
    • Desolder in a well ventilated area.
    • The tip of soldering iron is hot handle with caution.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 29
All Time: 395
