Brentwood TS-292B Bread Grabber Spring Replacement
  1. Brentwood TS-292B Bread Grabber Spring Replacement, Bread Grabber Spring: step 1, image 1 of 2 Brentwood TS-292B Bread Grabber Spring Replacement, Bread Grabber Spring: step 1, image 2 of 2
    • Turn the toaster upside down.
    • Remove the five 6 mm screws with a Phillips #2 screwdriver.
    Ask FixBot
  2. Brentwood TS-292B Bread Grabber Spring Replacement: step 2, image 1 of 2 Brentwood TS-292B Bread Grabber Spring Replacement: step 2, image 2 of 2
    • Grasp the plastic pull lever cover firmly and pull to remove it. This may require force.
    • Lift the cover upwards to remove it.
    • When removing the cover, do not damage the cable connector bundle that attaches the cover to the toaster.
    Ask FixBot
  3. Brentwood TS-292B Bread Grabber Spring Replacement: step 3, image 1 of 1
    • To detach the bundled cable connector, carefully pull it away from the circuit board.
    Ask FixBot
  4. Brentwood TS-292B Bread Grabber Spring Replacement: step 4, image 1 of 2 Brentwood TS-292B Bread Grabber Spring Replacement: step 4, image 2 of 2
    • Pull the toaster lever down.
    • While holding the toaster lever down, use the spudger to pull the metal tabs away from the wired bread grabber.
    • Continuing to hold the toaster lever down, pinch the wires inward and pull up to carefully remove them from the toaster.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 40
All Time: 803
