Up to 20% off select tools
Braven BRV-X Button Module(s) Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
9
Past 30 Days:
66
All Time:
937
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
If the buttons on your speaker are not working, they may need to be replaced. Use this guide to replace the button module on your Braven BRV-X.
    1. Braven BRV-X Button Module(s) Replacement, Front Speaker Panel: step 1, image 1 of 1
      • Remove four 1.1 cm outer screws in the outer shell using the Phillips #00 screwdriver.
      Ask FixBot
    2. Braven BRV-X Button Module(s) Replacement: step 2, image 1 of 1
      • Remove four 1.3 cm inner screws in the outer shell using the 1.5mm Hex screwdriver.
      Ask FixBot
    3. Braven BRV-X Button Module(s) Replacement: step 3, image 1 of 1
      • Gently remove the outer shell.
      Ask FixBot
    4. Braven BRV-X Button Module(s) Replacement: step 4, image 1 of 2 Braven BRV-X Button Module(s) Replacement: step 4, image 2 of 2
      • Cut adhesive tape on both sides.
      Ask FixBot
    5. Braven BRV-X Button Module(s) Replacement: step 5, image 1 of 2 Braven BRV-X Button Module(s) Replacement: step 5, image 2 of 2
      • Remove eighteen 0.9cm screws in the inner shell using the Phillips #00 screwdriver.
      Ask FixBot
    6. Braven BRV-X Button Module(s) Replacement: step 6, image 1 of 3 Braven BRV-X Button Module(s) Replacement: step 6, image 2 of 3 Braven BRV-X Button Module(s) Replacement: step 6, image 3 of 3
      • Pry open the glued inner shell using a spudger around all sides of the shell.
      • Don't use too much pressure as that could cause damage to the plastic.
      Ask FixBot
    7. Braven BRV-X Button Module(s) Replacement: step 7, image 1 of 2 Braven BRV-X Button Module(s) Replacement: step 7, image 2 of 2
      • Remove ten 0.7 cm screws in the front plate using the 1.5 mm Hex screwdriver.
      Ask FixBot
    8. Braven BRV-X Button Module(s) Replacement: step 8, image 1 of 2 Braven BRV-X Button Module(s) Replacement: step 8, image 2 of 2
      • Use a spudger to open the front speaker plate.
      Ask FixBot
    9. Braven BRV-X Button Module(s) Replacement: step 9, image 1 of 1
      • Remove three 1.0 cm screws from the battery unit.
      • It is recommended (but not required) to remove the battery.
      Ask FixBot
    10. Braven BRV-X Button Module(s) Replacement: step 10, image 1 of 2 Braven BRV-X Button Module(s) Replacement: step 10, image 2 of 2
      • Disconnect the ribbon cable attached the main board.
      Ask FixBot
    11. Braven BRV-X Button Module(s) Replacement: step 11, image 1 of 3 Braven BRV-X Button Module(s) Replacement: step 11, image 2 of 3 Braven BRV-X Button Module(s) Replacement: step 11, image 3 of 3
      • Pry open the second plate holding in the speaker using a spudger around all sides.
      • It is recommended to use a spudger to remove the heavily glued areas between the plates before prying.
      Ask FixBot
    12. Braven BRV-X Button Module(s) Replacement: step 12, image 1 of 3 Braven BRV-X Button Module(s) Replacement: step 12, image 2 of 3 Braven BRV-X Button Module(s) Replacement: step 12, image 3 of 3
      • Cut the 20 gauge wires attached to the front IR sensor and two speaker wires.
      • Leave enough length on the wire to work with it afterwards.
      • Cut the 22 gauge wire attached in the corner.
      • Solder the new speaker plate during reassembly.
      • To properly solder and desolder connections, visit the How to Solder and Desolder Connections guide.
      Ask FixBot
    1. Braven BRV-X Button Module(s) Replacement, Button Module(s): step 13, image 1 of 2 Braven BRV-X Button Module(s) Replacement, Button Module(s): step 13, image 2 of 2
      • Remove the ribbon cable attached to the main board.
      • Pull from the clip and not from the cable.
      Ask FixBot
    2. Braven BRV-X Button Module(s) Replacement: step 14, image 1 of 1
      • Remove three 0.7 cm screws from the button module(s) using the Phillips #00 screwdriver.
      Ask FixBot
    3. Braven BRV-X Button Module(s) Replacement: step 15, image 1 of 1
      • Gently lift the button module from the enclosure.
      Ask FixBot
Author
with
Trey Peterson
301 Reputation
2 Guides authored
IUPUI, Team S1-G5, Harley Spring 2019 Member of IUPUI, Team S1-G5, Harley Spring 2019
IUPUI-HARLEY-S19S1G5
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 66
All Time: 937
