Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓This is a step-by-step guide demonstrates how to remove the battery.
WARNING: This is a lithium battery which should be handled with care.
TIPS:
- Be sure to check the screwdriver heads before performing this task; otherwise, screws may become damaged.
- Use an ice cube tray or egg carton, place each screw in its own cup to organize the screws.
Tools
×2
Flip the Braven BRV-X upside down so you are facing the bottom side.
With the H1.5 Head Screwdriver, unscrew the four screws.
Using the #0 Phillips screwdriver, unscrew the four screws on the four corners of the bottom side.
Gently remove the outer casing, which should reveal the inner shell.
Remove the black foam squares from the red, yellow, and black wire on the top right side of the device.
Tool used on this step:Tweezers$4.99
Now that the three wires are exposed, follow the wires to the white base that is plugged into the motherboard.
Using the tech knife, carefully remove the glue that keeps the plug in place.
Using the tweezers, carefully disconnect the plug from the motherboard.
6 other people completed this guide.
11 Guide Comments
I also would love to know what battery is actually needed for this.
