Braven BRV-HD Battery Replacement
  1. Braven BRV-HD Battery Replacement, Battery: step 1, image 1 of 2 Braven BRV-HD Battery Replacement, Battery: step 1, image 2 of 2
    • Placing the device on its back with the BRV-HD logo facing up, remove the eight 5mm hexagon 2.0 screws on the front panel.
    • Make sure the device is turned off before starting.
    Ask FixBot
  2. Braven BRV-HD Battery Replacement: step 2, image 1 of 1
    • Lift the front panel off of the speaker using a plastic opening tool.
    Ask FixBot
  3. Braven BRV-HD Battery Replacement: step 3, image 1 of 2 Braven BRV-HD Battery Replacement: step 3, image 2 of 2
    • Placing the device with the back panel facing up, remove the eight 5mm hexagon 2.0 screws from the back panel.
    Ask FixBot
  4. Braven BRV-HD Battery Replacement: step 4, image 1 of 1
    • Lift the back panel off of the device with a plastic opening tool.
    Ask FixBot
  5. Braven BRV-HD Battery Replacement: step 5, image 1 of 2 Braven BRV-HD Battery Replacement: step 5, image 2 of 2
    • Turning the device on its side, unscrew the four 15mm hexagon 2.0 screws on the charging port panel.
    Ask FixBot
  6. Braven BRV-HD Battery Replacement: step 6, image 1 of 1
    • Remove the outer rubber flap and the plastic side port panel.
    Ask FixBot
  7. Braven BRV-HD Battery Replacement: step 7, image 1 of 2 Braven BRV-HD Battery Replacement: step 7, image 2 of 2
    • Place the device on its front.
    • Loosen the four 12mm Phillips screws in the four corners with a J1 screwdriver.
    • Loosen the two 8mm Phillips screws in the center with a J1 screwdriver.
    • These screws are difficult to reach and will require a screwdriver extension piece.
    Ask FixBot
  8. Braven BRV-HD Battery Replacement: step 8, image 1 of 1
    • Pull off the rubber sleeve surrounding the speaker using your hands.
    • There is adhesive binding the sleeve to the speaker and force will be required to remove the sleeve.
    Ask FixBot
  9. Braven BRV-HD Battery Replacement: step 9, image 1 of 1
    • Lift the black covering off of the speaker using both hands.
    • Loose screws that you were unable to remove with the screwdriver will be removed when you lift off the black covering.
    Ask FixBot
  10. Braven BRV-HD Battery Replacement: step 10, image 1 of 1
    • Remove the four 12mm Phillips screws securing the two battery brackets with a J1 screwdriver.
    • Move any wires aside to have better access to the screws securing the battery.
    Ask FixBot
  11. Braven BRV-HD Battery Replacement: step 11, image 1 of 1
    • Remove the two brackets that hold down the battery using your hands.
    Ask FixBot
  12. Braven BRV-HD Battery Replacement: step 12, image 1 of 2 Braven BRV-HD Battery Replacement: step 12, image 2 of 2
    • Use the plastic opening tool to lift up the battery.
    • Remove the battery using your hands.
    • The wires connecting the battery to the motherboard are still plugged in. Avoid pulling on the battery or these wires may break.
    Ask FixBot
  13. Braven BRV-HD Battery Replacement: step 13, image 1 of 1
    Tool used on this step:
    Buy
    • Disconnect the wire attaching the battery to the motherboard.
    • There is green glue on the wire ports preventing the wires from falling out. Peel and remove this glue as necessary.
    • Be careful when pulling out the wires from their ports. The metal stems attached to the ports can break. A spudger or tweezers may help.
    Ask FixBot
7 other people completed this guide.
Courtney Van Buren
330 Reputation
2 Guides authored
CSU Fullerton, Team 1-5, Bruce Fall 2016 Member of CSU Fullerton, Team 1-5, Bruce Fall 2016
CSUF-BRUCE-F16S1G5
5 Members
5 Guides authored
17 Guide Comments
Where can i order battery replacement
frdy vala - Reply Share
Found the battery on AliExpress and bought it Sept of 2018. Its an exact match! Label and all. Made by Hixon:
Hixon New 7.4V 4400mAh Replacement Battery for BRAVEN 850 Speaker-UL UN Certified
Price: US $36.99
Replacement for: BRAVEN 850, J177/ICR18650-22PM
It was shipped from SoCal too.
Rocko the fixit cat - Reply Share
Hello could you please share the link to the battery?
I cannot find it
Thanks!
arthur_69_63 - Reply Share
Also, to replace just the battery, you don’t need to take off the side port or front cover plate. And you don’t need to remove the whole rubber case cover. Just follow the instructions for the back side panel removal only. Peel the rubber case cover from around the edges of rear face plate so plate can be removed. Becarful with rubber case cover while pulling on it as if rubber is old, it may tear at the corners.
Reverse these steps for reassembly.
Note: my rubber case cover wasn’t glued on from the factory nor did I apply glue on reassembly, I don’t plan on dropping it in the water.
Thanks for confirming this. I was wondering this exact thing while looking at the guide.
Menelik Seth - Reply Share
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 75
All Time: 10,831
