Braven BRV-1s Outer Casing Replacement
  1. Braven BRV-1s Outer Casing Replacement, Outer Casing: step 1, image 1 of 1
    • To remove the outer case, remove 4 phillips screws (Phillips #00 headtype, 9.3mm long)
    Ask FixBot
  2. Braven BRV-1s Outer Casing Replacement: step 2, image 1 of 1
    • Using a metal spudger, gently pry the side of the defective case.
    Ask FixBot
  3. Braven BRV-1s Outer Casing Replacement: step 3, image 1 of 1
    • Still using the metal spudger, continue to work your way around the outer case.
    Ask FixBot
  4. Braven BRV-1s Outer Casing Replacement: step 4, image 1 of 1
    • Remove the broken outer case. Replace with used/new out case.
    • Note that unless properly sealed with glue, the speaker will no longer be water resistant.
    Ask FixBot
Cody Sprague
101 Reputation
1 Guide authored
IUPUI, Team S2-G2, Harley Spring 2017 Member of IUPUI, Team S2-G2, Harley Spring 2017
IUPUI-HARLEY-S17S2G2
4 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 18
All Time: 1,374
