Braven BRV-1M Battery Replacement
  1. Braven BRV-1M Battery Replacement, Outer Casing: step 1, image 1 of 1
    • To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
    Ask FixBot
  2. Braven BRV-1M Battery Replacement: step 2, image 1 of 1
    • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • A little resistance should be felt, but not enough to bend the spudger.
    Ask FixBot
  3. Braven BRV-1M Battery Replacement: step 3, image 1 of 1
    • To remove the inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the top side of the device.
    Ask FixBot
  4. Braven BRV-1M Battery Replacement: step 4, image 1 of 1
    • Carefully lift away the housing and replace the broken casing/component. Replace using the new casing.
    Ask FixBot
  5. Braven BRV-1M Battery Replacement, Motherboard: step 5, image 1 of 1
    • To remove the motherboard, proceed to unscrew the 3 Phillips #00 bit type, 13mm long screws located on both sides of the motherboard.
    Ask FixBot
  6. Braven BRV-1M Battery Replacement: step 6, image 1 of 1
    • Then, proceed to unscrew the 5 Phillips #00 bit type, 9mm long screws located on the face of the charging dock.
    Ask FixBot
  7. Braven BRV-1M Battery Replacement: step 7, image 1 of 1
    • Disconnect the two 4-pin auxiliary button register cables connected on both sides of the motherboard.
    Ask FixBot
  8. Braven BRV-1M Battery Replacement: step 8, image 1 of 1
    • Once disconnected, carefully remove the motherboard by pulling upwards.
    Ask FixBot
  9. Braven BRV-1M Battery Replacement, Battery: step 9, image 1 of 1
    • To remove the battery, unscrew the 2 Phillips #00 bit type, 9 mm long screws on both sides of the battery.
    Ask FixBot
  10. Braven BRV-1M Battery Replacement: step 10, image 1 of 1
    • Gently pull the battery from the housing of the device while disconnecting the red, white and black wires coming from the battery.
    Ask FixBot
Erik Oliva
607 Reputation
6 Guides authored
USF Tampa, Team S2-G1, Eyestone Spring 2018 Member of USF Tampa, Team S2-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S2G1
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 42
All Time: 3,111
