Braun Trimmer Battery Replacement and Modification
Views: 17K
View statistics:
Past 24 Hours:
14
Past 7 Days:
198
Past 30 Days:
907
All Time:
17,191
Comments: 7
5 comments on steps, 2 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 3 hours
Difficulty: Moderate
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Introduction
Go to step 1 ↓
In this guide, I describe how I replaced rechargeable batteries in my Braun Trimmer. The original batteries started losing their capacity after the first year of using the trimmer. So I decided to include a 3D-printed battery case in the trimmer to ease the process of battery replacement in the future. Plus, this approach doesn't require any soldering that could potentially harm the new batteries.
    1. Braun Trimmer Battery Replacement and Modification, Disassemble the trimmer: step 1, image 1 of 1
      • First you need to disassemble the trimmer.
      • To access the four screws you would need first to open the frontal cover. Use opening picks, starting from the bottom of the trimmer
      • For detailed disassembly refer to another article on iFixit
      Ask FixBot
    2. Braun Trimmer Battery Replacement and Modification, Print a holder for the batteries: step 2, image 1 of 3 Braun Trimmer Battery Replacement and Modification, Print a holder for the batteries: step 2, image 2 of 3 Braun Trimmer Battery Replacement and Modification, Print a holder for the batteries: step 2, image 3 of 3
      • Print a holder for your new batteries on a 3D printer
      • I used a modified 3D model from ThingVerse
      • The original model is too big for the trimmer case. I modified the scale like following: X 97%, Y 84%; Z 95%
      • I stopped the printing at 60% of completion to keep the holder low enough to fit the trimmer case
      Ask FixBot
    3. Braun Trimmer Battery Replacement and Modification, Remove the old batteries: step 3, image 1 of 1
      • Remove the original dead batteries
      • I didn't have a soldering iron, so I used a heated knife to slowly detach the batteries from the connectors. It worked okay
      Ask FixBot
    4. Braun Trimmer Battery Replacement and Modification, Attach the printed batteries holder: step 4, image 1 of 2 Braun Trimmer Battery Replacement and Modification, Attach the printed batteries holder: step 4, image 2 of 2
      • Place the 3D-printed battery case on the board so the connectors would go inside the case as you see on the pictures
      Ask FixBot
    5. Braun Trimmer Battery Replacement and Modification, Place the new batteries: step 5, image 1 of 3 Braun Trimmer Battery Replacement and Modification, Place the new batteries: step 5, image 2 of 3 Braun Trimmer Battery Replacement and Modification, Place the new batteries: step 5, image 3 of 3
      • Place the new batteries into the case. Pay attention to polarities
      • Before full assembly, you can test if the new batteries are charging
      Ask FixBot
    6. Braun Trimmer Battery Replacement and Modification, Test: step 6, image 1 of 2 Braun Trimmer Battery Replacement and Modification, Test: step 6, image 2 of 2
      • After the battery has fully charged the trimmer should work as new
      Ask FixBot
    7. Braun Trimmer Battery Replacement and Modification, Assemble: step 7, image 1 of 3 Braun Trimmer Battery Replacement and Modification, Assemble: step 7, image 2 of 3 Braun Trimmer Battery Replacement and Modification, Assemble: step 7, image 3 of 3
      • Now you should be ready to assemble the trimmer back
      Ask FixBot
    8. Braun Trimmer Battery Replacement and Modification, Profit: step 8, image 1 of 2 Braun Trimmer Battery Replacement and Modification, Profit: step 8, image 2 of 2
      • Enjoy the proper working time of your refreshed trimmer
      Ask FixBot
My old batteries barely lasted one minute of shaving, and never held any charge. I didn't test the full working time of the new batteries, but they allowed me to use the trimmer at least for 10 minutes.
Thanks to adding the battery holder next battery replacement would be way easier and faster.
8 other people completed this guide.
elwiwian
463 Reputation
1 Guide authored
2 Guide Comments
Would you provide the specs of the original batteries (mAh and Voltage)? So one can order spare parts in advance.
h4fnp - Reply Share
@hffnp the batteries depend on your exact unit. Some use a single SANYO CH UR14500AC LI-ION 740MAH (https://www.youtube.com/watch?v=nCjZmS0h...). mine, and probably the OP's, were two SUPPO HS-AAA0.75 NIMH 1.2V, aka ordinary AAA NiMH 1.2volt 750mAh batteries. Thats why they used ordinary rechargeable AAAs as replacements. Some other models use a single AAA, but of the same specs (https://www.youtube.com/watch?v=P16yy_3F...)
SBN - Reply Share
Past 24 Hours: 14
Past 7 Days: 198
Past 30 Days: 907
All Time: 17,191
