Braun Shaver Model 7680 Battery Replacement
    1. Braun Shaver Model 7680 Battery Replacement, Battery: step 1, image 1 of 1
      • Soldering is required to install this battery one or two batteries may be required verify how many you need before you order
      Ask FixBot
    2. Braun Shaver Model 7680 Battery Replacement, Remove bottom cover: step 2, image 1 of 2 Braun Shaver Model 7680 Battery Replacement, Remove bottom cover: step 2, image 2 of 2
      • First pry the left side of the cover off, then pry the right side of the cover off before removing. Trying to pry the cover off from only one side will result in breaking the plastic tabs.
      Ask FixBot
    3. Braun Shaver Model 7680 Battery Replacement, Remove side covers: step 3, image 1 of 1
      • Pull the side covers off from the bottom, they hinge from the top and will come off freely once you rotate them up and away from the body starting at the bottom.
      Ask FixBot
    4. Braun Shaver Model 7680 Battery Replacement, Remove screws on back: step 4, image 1 of 2 Braun Shaver Model 7680 Battery Replacement, Remove screws on back: step 4, image 2 of 2
      • You will need a T9 hex screw driver.
      Ask FixBot
      • R17 AA NiMh Battery With Pin Tabs 1650 Mah 1.2V Battery Measures .559" x 1.97", 14.2mm x 50mm
      Ask FixBot
      • Replacing the batteries will not always repair the shaver, the circuit board may be bad, if the indicator lights on the circuit board do not light up when plugged in the circuit board is most likely bad, you should replace the entire circuit board and battery assembly.
      Ask FixBot
19 other people completed this guide.
mayer
690,574 Reputation
11 Guides authored
8 Guide Comments
Great tutorial. It was all I needed, since I wasn't sure how to get the case open. Thanks!
mikebailey - Reply Share
Thanks for the tutorial! Mine had intermittent problem with the on/off switch and I was googling how to open the case. Easy and simple, bets razor I’ve had and not willing to change :D
Tero Kortetmäki - Reply Share
Thanks for the tutorial… but it is a T8 Torx at least in the Model 7570. I just had to take out the recharchable batteries to get mine working properly again.
A Krueger - Reply Share
Danke für die übersichtliche Anleitung, hat mir gut geholfen. Die wichtige Frage ist immer:
Wie geht ‘s Gehäuse auf. ?
Garofalo - Reply Share
Thanks for the guide! Without knowing how to open the case, replacing the battery would have been a lost cause. In my case the batteries were tired. After replacing and recharging them the razor sounds young again and full of pep.
Stephen Spratley - Reply Share
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 111
All Time: 25,332
