Braun Multimix maintain gearing
Views: 3.9K
View statistics:
Past 24 Hours:
7
Past 7 Days:
64
Past 30 Days:
236
All Time:
3,852
Comments: 7
7 comments on steps.
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓
Symptom: the Multimix is running fine without load but it can easily be stopped by hand and a gentle squeaking sound is noticeable.
The cause for this is most likely a broken sprocket on the motor shaft.
To repair this, either a new set of wheels can be installed or the main sprocket can be tried to be glued together.
For the repair, you can either order a new set of gears for the gearbox or try to glue the gear.
Tools required:
Plastic spatula
Thin slotted screwdriver
Philips #2, PH2 screwdriver
Tools
    1. Braun Multimix maintain gearing, Remove cover on the underside: step 1, image 1 of 2 Braun Multimix maintain gearing, Remove cover on the underside: step 1, image 2 of 2
      • Put the device head over
      • Lift the cover on the rear end (maybe add another spudge to lift a bit more)
      • Push the cover to the rear end (cord inlet)
      Ask FixBot
    2. Braun Multimix maintain gearing, Remove front cover: step 2, image 1 of 2 Braun Multimix maintain gearing, Remove front cover: step 2, image 2 of 2
      • Lift from the side of the cover and remove cover.
      • Remove PH2 screw
      Ask FixBot
    3. Braun Multimix maintain gearing, Remove back cover: step 3, image 1 of 3 Braun Multimix maintain gearing, Remove back cover: step 3, image 2 of 3 Braun Multimix maintain gearing, Remove back cover: step 3, image 3 of 3
      • With one or more spudgers lift the back cover slightly
      • With a small screwdriver push in the middle of the cover to release the nose (see pic 3)
      Ask FixBot
    4. Braun Multimix maintain gearing: step 4, image 1 of 3 Braun Multimix maintain gearing: step 4, image 2 of 3 Braun Multimix maintain gearing: step 4, image 3 of 3
      • Release the retainer tabs around the casing
      • Best is to begin on the underside of the device, looking in from behind you can see the retainer tab and release it with a small screwdriver or spudger.
      • In picture 3 you can see all retainer locations.
      Ask FixBot
    1. Braun Multimix maintain gearing, Gear drive in the transmission: step 5, image 1 of 1
      • After opening the case, remove the motor and electronics from the casing. It might be helpful to press the release button (green part).
      Ask FixBot
    2. Braun Multimix maintain gearing: step 6, image 1 of 1
      • To remove the release button, push down till retainer nose is free and the button can be pushed away from the motor.
      Ask FixBot
    3. Braun Multimix maintain gearing: step 7, image 1 of 1
      • Remove the 3 T10 screws and release the 3 retainer tabs.
      • Hold the motor with the gearing on top and lift the white enclosure.
      Ask FixBot
    4. Braun Multimix maintain gearing: step 8, image 1 of 1
      • Check gears and replace if needed.
      • In my case the sprocket on the motor shaft was broken along a tooth. Under load it lost contact and the motor could turn without the gears moving. I tried fixing it by glueing with some 2K epoxy.
      • When assembling the gear set, make sure that the two large gears – which support the beaters – are positioned so that the beaters are offset from each other. The most accurate way to do this is with the beaters temporarily inserted.
      Ask FixBot
Follow the instructions in reverse order to reassemble the device
6 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Chris
696 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 64
Past 30 Days: 236
All Time: 3,852
