Up to 20% off select tools
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Braun Digital Alarm Clock: Spring Replacement
View statistics:
Past 24 Hours:
11
Past 7 Days:
47
Past 30 Days:
223
All Time:
921
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Use this guide to access, work on, or replace the spring for the alarm function of your Braun digital alarm clock. A faulty spring can cause the alarm function to remain permanently enabled.
    1. Braun Digital Alarm Clock: Spring Replacement, Remove the plexiglass plate: step 1, image 1 of 3 Braun Digital Alarm Clock: Spring Replacement, Remove the plexiglass plate: step 1, image 2 of 3 Braun Digital Alarm Clock: Spring Replacement, Remove the plexiglass plate: step 1, image 3 of 3
      Tool used on this step:
      Suction Handle
      $2.95
      Buy
      • Lift the plexiglass plate with a suction cup and use opening picks to separate it from the alarm clock.
      Ask FixBot
    2. Braun Digital Alarm Clock: Spring Replacement, Remove the frame: step 2, image 1 of 2 Braun Digital Alarm Clock: Spring Replacement, Remove the frame: step 2, image 2 of 2
      Phillips #00 Screwdriver
      $5.49
      Buy
      • Remove the four red-marked screws behind the plexiglass panel with a Phillips #00 screwdriver.
      • Remove the frame to expose the display.
      Ask FixBot
    3. Braun Digital Alarm Clock: Spring Replacement, Fold the display away: step 3, image 1 of 2 Braun Digital Alarm Clock: Spring Replacement, Fold the display away: step 3, image 2 of 2
      • Fold the display back.
      • A loose diffuser sheet is located between the display and the PCB. Remove it and set it aside for reassembly.
      Ask FixBot
    4. Braun Digital Alarm Clock: Spring Replacement, Fold away the PCB: step 4, image 1 of 2 Braun Digital Alarm Clock: Spring Replacement, Fold away the PCB: step 4, image 2 of 2
      • Fold the display and PCB together to the left.
      • Carefully detach the lightly glued, red-marked capacitor on the right for better access.
      Ask FixBot
    5. Braun Digital Alarm Clock: Spring Replacement, Remove the plastic clip: step 5, image 1 of 2 Braun Digital Alarm Clock: Spring Replacement, Remove the plastic clip: step 5, image 2 of 2
      Spudger
      $3.99
      Buy
      • Pry out the red-marked plastic clip with a spudger. It holds the small upper PCB with the switches for the alarm function in place.
      Ask FixBot
    6. Braun Digital Alarm Clock: Spring Replacement, Editing or replacing the spring: step 6, image 1 of 2 Braun Digital Alarm Clock: Spring Replacement, Editing or replacing the spring: step 6, image 2 of 2
      • Remove the upper PCB.
      • Stretch, compress, or replace the spring depending on its condition.
      • For reassembly, it may be helpful to secure the spring to the green switch.
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
Author
with
Fidecaro
265 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 47
Past 30 Days: 223
All Time: 921
