Braun BT5090 Battery Replacement
Views: 42K
View statistics:
Past 24 Hours:
9
Past 7 Days:
103
Past 30 Days:
569
All Time:
41,965
Comments: 21
4 comments on steps, 17 guide comments.
Go to guide comments
Completed: 25
25 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Community-Contributed Guide
    1. Braun BT5090 Battery Replacement, Remove the trim head: step 1, image 1 of 1
      • Fold down the trim head
      • Remove the trim head by gently pulling
      Ask FixBot
    2. Braun BT5090 Battery Replacement, Opening of the housing: step 2, image 1 of 3 Braun BT5090 Battery Replacement, Opening of the housing: step 2, image 2 of 3 Braun BT5090 Battery Replacement, Opening of the housing: step 2, image 3 of 3
      • Unscrew the 2 screws at the front under the blade.
      • Use tweezers to remove the clip.
      • Push the part of plastic body in an upwards direction to separate the case.
      Ask FixBot
    3. Braun BT5090 Battery Replacement, Opening of the housing: step 3, image 1 of 1
      • Use the iFixit picks or a similar tool to run along the edge between the top and bottom pieces to loosen the retaining clips.
      • Slide the whole plastic body up (towards the trim head) to open it.
      Ask FixBot
    4. Braun BT5090 Battery Replacement, Opening of the waterproof inside assembly: step 4, image 1 of 3 Braun BT5090 Battery Replacement, Opening of the waterproof inside assembly: step 4, image 2 of 3 Braun BT5090 Battery Replacement, Opening of the waterproof inside assembly: step 4, image 3 of 3
      • With gentle pressure from the opposite side, you can carefully remove the inner module and motor from the housing.
      • Use a small flat screwdriver to loosen the 6 clips on the module
      • Remove the cover by pulling straight up
      • Carefully bend the two pieces of metal that make contact with the charger upwards.
      Ask FixBot
    5. Braun BT5090 Battery Replacement, Replacing the batteries: step 5, image 1 of 3 Braun BT5090 Battery Replacement, Replacing the batteries: step 5, image 2 of 3 Braun BT5090 Battery Replacement, Replacing the batteries: step 5, image 3 of 3
      • Carefully lever the PCB up and out. The PCB is held by 2 small hooks approximately in the middle. Spread the housing slightly while you carefully lift out the PCB, e.g. using a small screwdriver on the batteries.
      • If you unscrew the motor, you have two openings that you can lever across. Take care not to damage the 2 cables to the motor.
      • Desolder the old batteries from the PCB. These can also be snipped off as far up as possible with a side cutter
      • Solder the new batteries to the lugs on the PCB where the old batteries were previously soldered.
      Ask FixBot
    6. Braun BT5090 Battery Replacement, Solder new batteries in place: step 6, image 1 of 3 Braun BT5090 Battery Replacement, Solder new batteries in place: step 6, image 2 of 3 Braun BT5090 Battery Replacement, Solder new batteries in place: step 6, image 3 of 3
      • If your replacement batteries does not come with its own flags, you still have to unsolder the original flags from the batteries. That doesn't work so well. It is better to use new ones.
      • Use desoldering braid to remove the solder from the solder joints.
      • Be careful not to damage other components
      • Each of the original batteries is a NiMH battery, 1.2V
      • The spare battery pack used here is a 950mAh, 2.4V, NiMH (AAA)
      Ask FixBot
    7. Braun BT5090 Battery Replacement, New batteries installed: step 7, image 1 of 2 Braun BT5090 Battery Replacement, New batteries installed: step 7, image 2 of 2
      • Lay the cables to the motor past the LEDs
      • Glue the small foam spacer back onto the cables
      • Carefully reseal the housing, making sure the gasket is seated properly and the clips are all fully engaged.
      Ask FixBot
25 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
twayne Markinson
1,500 Reputation
6 Guides authored
17 Guide Comments
Danke für die gute Anleitung. Es wäre noch schön zu lesen gewesen, ob es sich um “Micro” (AAA; HR6) oder “Mignon” (AA, HR3) Akkus handelt und welche mAh-Kapazität mindest erfordert wird und welche maximale Kapazität sinnvoll ist.
Ingo Evergrey - Reply Share
Hallo,
diese Infos habe Ich leider auch nicht. Ich habe folgende Akkus verwendet:
https://www.pollin.de/p/nimh-micro-akku-...
Viele Grüße
twayne Markinson - Reply Share
Beim Entfernen des Deckels ist es günstig von hinten (wo der Netzstecker sitzt) zu beginnen. Etwas Druck unter den Deckel mit eine Hebel geben ( Küchenmesser stumpf). Nun jeweils die beiden (linken und rechten) Clips lösen von unten nach oben zum Motor hin ;-)
Achtung, im Deckel sitzt eine Dichtung. Diese nicht beschädigen!!!
Zum entlöten der Kontaktfahnen am besten noch Entlötlitze benutzten! So wird verhindert, das Lötperlen irgendwo hin tropfen wo sie nicht hingehören.
Lutz Reber - Reply Share
Hallo Lutz, danke für deinen Kommentar und die Hinweise! Bei unseren Anleitungen ist es wie bei Wikipedia, alle können sich einbringen. Du kannst deine Hinweise also auch direkt in die Anleitung schreiben. Nur als Info. ;)
Fabian Neidhardt - Reply Share
Hello gentleman. How do I remove the batteries? I heated the metal terminals that connect to the batteries but the little spot welds do not melt away. Is there a way to do this simply or is it better to just cut it as high as I can as mentioned? Thank you!
Daniel Nunes - Reply Share
Past 24 Hours: 9
Past 7 Days: 103
Past 30 Days: 569
All Time: 41,965
