Bralette Foam Insert Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
86
All Time:
608
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 4 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Most bralettes have foam inserts to provide support and shape. Over time, the use of the bralette will cause the foam inserts to be worn out and reshaped. We must replace the old insert with the new ones to gain back the support and shape it once gave.
    1. Bralette Foam Insert Replacement, Foam Inserts: step 1, image 1 of 1
      • Lay out the bralette in a clean and flat place.
      Ask FixBot
    2. Bralette Foam Insert Replacement: step 2, image 1 of 1
      • Find the foam insert pockets.
      • These are usually found in the cups or sides of the bralette.
      Ask FixBot
    3. Bralette Foam Insert Replacement: step 3, image 1 of 1
      • Take out the existing foam inserts by carefully pulling them from their pockets.
      Ask FixBot
    4. Bralette Foam Insert Replacement: step 4, image 1 of 1
      • Use a lint roller to remove lint or dirt in the pockets.
      Ask FixBot
    5. Bralette Foam Insert Replacement: step 5, image 1 of 1
      • Select the right roam inserts that have the perfect size and thickness for the bralette.
      Ask FixBot
    6. Bralette Foam Insert Replacement: step 6, image 1 of 2 Bralette Foam Insert Replacement: step 6, image 2 of 2
      • Slide the replacement foam insert into the pocket of the bralette.
      • Make sure no bumps are present.
      Ask FixBot
    7. Bralette Foam Insert Replacement: step 7, image 1 of 1
      • Once inserted, make sure the foam inserts are in the correct place and give the ideal shape and support.
      Ask FixBot
    8. Bralette Foam Insert Replacement: step 8, image 1 of 1
      • Put the bralette on to check the shape and support of the replacement foam inserts.
      • Make any improvements if required.
      Ask FixBot
You did it! You have replaced your old foam inserts to revamp your favourite bralette.
Tasnuva Bushra
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 86
All Time: 608
