Up to 20% off select tools
Bottom Cover
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
87
All Time:
651
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 - 5 minutes
Difficulty: Easy
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Bottom Cover
Tools
    1. Bottom Cover, Battery: step 1, image 1 of 1
      • Before proceeding, power down your Laptop and remove the power cable.
      • Close the display and lay it on a flat surface, top-side down.
      Ask FixBot
    2. Bottom Cover: step 2, image 1 of 1
      • Unlock the battery by sliding the battery lock to the unlock part.
      Ask FixBot
    3. Bottom Cover: step 3, image 1 of 1
      • Slide the middle lock to the right and the battery will pop up.
      Ask FixBot
    4. Bottom Cover: step 4, image 1 of 1
      • If you want to replace the battery and nothing else then now is the time to do so.
      • Once the battery hatch is unlocked you can now safely remove the battery.
      Ask FixBot
    1. Bottom Cover, Bottom Cover: step 5, image 1 of 1
      • Use a Philips J1 driver to remove eight screws securing the bottom case.
      • Remove all of the 8 screws and the bottom panel should pop off.
      Ask FixBot
    2. Bottom Cover: step 6, image 1 of 1
      • After that you are in and now can change most of the components, which we also have tutorials for.
      Ask FixBot
Author
with
Regome
866 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 87
All Time: 651
