Up to 20% off select tools
Bottom Board Removal
Views: 6.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
159
All Time:
6,717
Comments: 5
5 comments on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
    1. Bottom Board Removal, Engage Wired Optical Mouse Top and Outer Shell Removal: step 1, image 1 of 1
      • Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
      Ask FixBot
    2. Bottom Board Removal: step 2, image 1 of 1
      • Use the Phillips #1 screwdriver to remove four 5 mm screws from the bottom of the mouse.
      • Use the Phillips #1 screwdriver to remove the two 9 mm screws from the bottom of the mouse.
      Ask FixBot
    3. Bottom Board Removal: step 3, image 1 of 3 Bottom Board Removal: step 3, image 2 of 3 Bottom Board Removal: step 3, image 3 of 3
      • Grab the top shell of the mouse and lift up to remove.
      Ask FixBot
    4. Bottom Board Removal: step 4, image 1 of 1
      • The capacitors on this board can release stored electrical energy if touched.
      • Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
      Ask FixBot
    5. Bottom Board Removal: step 5, image 1 of 2 Bottom Board Removal: step 5, image 2 of 2
      • Use a spudger to pry underneath the white plug and pop it out to disconnect the upper board from the lower board.
      Ask FixBot
    1. Bottom Board Removal, Side Panels: step 6, image 1 of 2 Bottom Board Removal, Side Panels: step 6, image 2 of 2
      • Locate the 5 mm silver flat head mounting screws (2) to the left and right of the scroll wheel and remove with the Phillips #1 screwdriver.
      Ask FixBot
    2. Bottom Board Removal: step 7, image 1 of 2 Bottom Board Removal: step 7, image 2 of 2
      • Locate the snaps on the bottom corners of the mouse side panels and pop the indicated snaps out, using a spudger or your fingernail.
      Ask FixBot
    3. Bottom Board Removal: step 8, image 1 of 3 Bottom Board Removal: step 8, image 2 of 3 Bottom Board Removal: step 8, image 3 of 3
      • Repeat Step 6 for the opposite side panel in order to detach both sides from the base of the mouse.
      Ask FixBot
    4. Bottom Board Removal: step 9, image 1 of 2 Bottom Board Removal: step 9, image 2 of 2
      • Grab the sides of the mouse and lift them up to detach from the base of the mouse.
      Ask FixBot
    1. Bottom Board Removal, Bottom Board: step 10, image 1 of 2 Bottom Board Removal, Bottom Board: step 10, image 2 of 2
      • Pop the scroll wheel out of the snap holding it in place. You can use your finger or a spudger to do so.
      Ask FixBot
    2. Bottom Board Removal: step 11, image 1 of 2 Bottom Board Removal: step 11, image 2 of 2
      • Locate the four 5 mm black flat head screws on the corners of the bottom board.
      • Unscrew these four black screws.
      Ask FixBot
    3. Bottom Board Removal: step 12, image 1 of 3 Bottom Board Removal: step 12, image 2 of 3 Bottom Board Removal: step 12, image 3 of 3
      • Lift the bottom board up to remove from its mounting posts. This will separate it completely from the bottom panel of the mouse.
      Ask FixBot
4 other people completed this guide.
Author
with
royceeklund
115 Reputation
3 Guides authored
Cal Poly, Team 18-36, Regan Winter 2013 Member of Cal Poly, Team 18-36, Regan Winter 2013
CPSU-REGAN-W13S18G36
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 159
All Time: 6,717
