Boss RC-1 Loop Station-Pedal Battery Replacement
    1. Boss RC-1 Loop Station-Pedal Battery Replacement, Battery: step 1, image 1 of 1
      • Push down on the pedal in order to relieve pressure on the thumbscrew.
      Ask FixBot
    2. Boss RC-1 Loop Station-Pedal Battery Replacement: step 2, image 1 of 1
      • Remove the thumb screw at the bottom of the device.
      • Loosening the thumb screw far enough will also allow the pedal to open.
      Ask FixBot
    3. Boss RC-1 Loop Station-Pedal Battery Replacement: step 3, image 1 of 2 Boss RC-1 Loop Station-Pedal Battery Replacement: step 3, image 2 of 2
      • Using the Phillips #0 screwdriver, remove the two screws that secure the pedal to the device.
      Ask FixBot
    4. Boss RC-1 Loop Station-Pedal Battery Replacement: step 4, image 1 of 1
      • Take the battery out of the device.
      Ask FixBot
    5. Boss RC-1 Loop Station-Pedal Battery Replacement: step 5, image 1 of 1
      • Disconnect the snap chord from the battery.
      Ask FixBot
    6. Boss RC-1 Loop Station-Pedal Battery Replacement: step 6, image 1 of 1
      • Reassemble the device in the opposite order.
      • When tightening the thumbscrew back in the device, apply force to the pedal first (Do step 1 before step 2).
      Ask FixBot
To check if the batter replacement was successful, plug in a guitar cable into the “Output A” jack. If the red light turns on below the “check” (top of the device), then the looper pedal is working.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 77
All Time: 7,969
