Boss CE-300 Super Chorus Switches Replacement
  1. Boss CE-300 Super Chorus Switches Replacement, Top Panel: step 1, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the 3 14.8 mm screws located on the left side of the CE-300.
    • Repeat the previous bullet on the right side.
    Ask FixBot
  2. Boss CE-300 Super Chorus Switches Replacement: step 2, image 1 of 1
    • Remove the two 10 mm bolts using a Phillips #2 screwdriver.
    Ask FixBot
  3. Boss CE-300 Super Chorus Switches Replacement: step 3, image 1 of 1
    • On the back of the CE-300, remove the two 7.5 mm screws with a Phillips #2 screwdriver.
    Ask FixBot
  4. Boss CE-300 Super Chorus Switches Replacement: step 4, image 1 of 1
    • On the left side, remove the one 10 mm screws with a Phillips #2 screwdriver.
    Ask FixBot
  5. Boss CE-300 Super Chorus Switches Replacement: step 5, image 1 of 2 Boss CE-300 Super Chorus Switches Replacement: step 5, image 2 of 2
    • Slide the top panel away from the front.
    • Lift the panel up and off.
    Ask FixBot
  6. Boss CE-300 Super Chorus Switches Replacement, Bottom Panel: step 6, image 1 of 1
    • Remove the following screws with a Phillips #2 screwdriver:​
    • Two 7.5 mm
    • Two 10 mm
    Ask FixBot
  7. Boss CE-300 Super Chorus Switches Replacement: step 7, image 1 of 2 Boss CE-300 Super Chorus Switches Replacement: step 7, image 2 of 2
    • Lift the bottom panel up and off.
    Ask FixBot
  8. Boss CE-300 Super Chorus Switches Replacement, Face plate: step 8, image 1 of 1
    • Remove the single 5.7 mm screw on the left side of the face plate.
    • Repeat the previous step on the right side of the face plate.
    Ask FixBot
  9. Boss CE-300 Super Chorus Switches Replacement: step 9, image 1 of 2 Boss CE-300 Super Chorus Switches Replacement: step 9, image 2 of 2
    • Remove all dial covers.
    Ask FixBot
  10. Boss CE-300 Super Chorus Switches Replacement: step 10, image 1 of 3 Boss CE-300 Super Chorus Switches Replacement: step 10, image 2 of 3 Boss CE-300 Super Chorus Switches Replacement: step 10, image 3 of 3
    • From the inside of the unit, pinch the 3 clips holding the faceplate in
    • Do not use any metal tool to pinch the clips. If metal damages the board, it may be unrepairable.
    • Push the clips in and the face plate will slide off.
    Ask FixBot
  11. Boss CE-300 Super Chorus Switches Replacement: step 11, image 1 of 1
    • With a 11 mm wrench or socket, remove the five nuts around the dials.
    Ask FixBot
  12. Boss CE-300 Super Chorus Switches Replacement: step 12, image 1 of 1
    • With a 14 mm wrench or socket, remove the three nuts around the jacks.
    Ask FixBot
  13. Boss CE-300 Super Chorus Switches Replacement: step 13, image 1 of 2 Boss CE-300 Super Chorus Switches Replacement: step 13, image 2 of 2
    • Remove the three switch covers.
    Ask FixBot
  14. Boss CE-300 Super Chorus Switches Replacement: step 14, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the single 7.8 mm screw on the left side of the bracket.
    • Repeat the previous bullet on the right side of the bracket.
    Ask FixBot
  15. Boss CE-300 Super Chorus Switches Replacement: step 15, image 1 of 2 Boss CE-300 Super Chorus Switches Replacement: step 15, image 2 of 2
    • Remove the two audio jacks that are to the side.
    • Do not pull the face bracket fully off and away. Some cables will remain attached to the face bracket and to the board.
    • Carefully remove the face bracket by sliding it forward until it clears all dials, then lift up.
    Ask FixBot
  16. Boss CE-300 Super Chorus Switches Replacement, Switches: step 16, image 1 of 2 Boss CE-300 Super Chorus Switches Replacement, Switches: step 16, image 2 of 2
    • From the "top" of the board, desolder the marked joints.
    • For some switches, the board is labeled to help identify the correct switch. The switch shown in the second picture is the "Direct Mute" switch.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 14
All Time: 165
