Boss CE-300 Super Chorus Fuse Replacement
    1. Boss CE-300 Super Chorus Fuse Replacement, Bottom Panel: step 1, image 1 of 1
      • Remove the following screws with a Phillips #2 screwdriver:​
      • Two 7.5 mm
      • Two 10 mm
      Ask FixBot
    2. Boss CE-300 Super Chorus Fuse Replacement: step 2, image 1 of 2 Boss CE-300 Super Chorus Fuse Replacement: step 2, image 2 of 2
      • Lift the bottom panel up and off.
      Ask FixBot
    1. Boss CE-300 Super Chorus Fuse Replacement, Fuse: step 3, image 1 of 2 Boss CE-300 Super Chorus Fuse Replacement, Fuse: step 3, image 2 of 2
      • Once the bottom plate is removed, you have clear access to the fuse shown​.
      • Optional: To test the fuse, use a multimeter in the continuity setting. ​ Place the probes on each end of the fuse (polarity does not matter), if the fuse is good, the multimeter should beep.​
      Ask FixBot
    2. Boss CE-300 Super Chorus Fuse Replacement: step 4, image 1 of 2 Boss CE-300 Super Chorus Fuse Replacement: step 4, image 2 of 2
      • Use an opening tool to carefully remove the fuse. ​ ​
      • Avoid using metal tools near the motherboard. Any accident could break more complex components. ​
      • You may visually inspect the fuse and compare it to a replacement 0.5A fuse.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Rashed
285 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 30
All Time: 274
