Boss CE-300 Super Chorus Dial Replacement
  1. Boss CE-300 Super Chorus Dial Replacement, Top Panel: step 1, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the 3 14.8 mm screws located on the left side of the CE-300.
    • Repeat the previous bullet on the right side.
    Ask FixBot
  2. Boss CE-300 Super Chorus Dial Replacement: step 2, image 1 of 1
    • Remove the two 10 mm bolts using a Phillips #2 screwdriver.
    Ask FixBot
  3. Boss CE-300 Super Chorus Dial Replacement: step 3, image 1 of 1
    • On the back of the CE-300, remove the two 7.5 mm screws with a Phillips #2 screwdriver.
    Ask FixBot
  4. Boss CE-300 Super Chorus Dial Replacement: step 4, image 1 of 1
    • On the left side, remove the one 10 mm screws with a Phillips #2 screwdriver.
    Ask FixBot
  5. Boss CE-300 Super Chorus Dial Replacement: step 5, image 1 of 2 Boss CE-300 Super Chorus Dial Replacement: step 5, image 2 of 2
    • Slide the top panel away from the front.
    • Lift the panel up and off.
    Ask FixBot
  6. Boss CE-300 Super Chorus Dial Replacement, Bottom Panel: step 6, image 1 of 1
    • Remove the following screws with a Phillips #2 screwdriver:​
    • Two 7.5 mm
    • Two 10 mm
    Ask FixBot
  7. Boss CE-300 Super Chorus Dial Replacement: step 7, image 1 of 2 Boss CE-300 Super Chorus Dial Replacement: step 7, image 2 of 2
    • Lift the bottom panel up and off.
    Ask FixBot
  8. Boss CE-300 Super Chorus Dial Replacement, Face plate: step 8, image 1 of 1
    • Remove the single 5.7 mm screw on the left side of the face plate.
    • Repeat the previous step on the right side of the face plate.
    Ask FixBot
  9. Boss CE-300 Super Chorus Dial Replacement: step 9, image 1 of 2 Boss CE-300 Super Chorus Dial Replacement: step 9, image 2 of 2
    • Remove all dial covers.
    Ask FixBot
  10. Boss CE-300 Super Chorus Dial Replacement: step 10, image 1 of 3 Boss CE-300 Super Chorus Dial Replacement: step 10, image 2 of 3 Boss CE-300 Super Chorus Dial Replacement: step 10, image 3 of 3
    • From the inside of the unit, pinch the 3 clips holding the faceplate in
    • Do not use any metal tool to pinch the clips. If metal damages the board, it may be unrepairable.
    • Push the clips in and the face plate will slide off.
    Ask FixBot
  11. Boss CE-300 Super Chorus Dial Replacement: step 11, image 1 of 1
    • With a 11 mm wrench or socket, remove the five nuts around the dials.
    Ask FixBot
  12. Boss CE-300 Super Chorus Dial Replacement: step 12, image 1 of 1
    • With a 14 mm wrench or socket, remove the three nuts around the jacks.
    Ask FixBot
  13. Boss CE-300 Super Chorus Dial Replacement: step 13, image 1 of 2 Boss CE-300 Super Chorus Dial Replacement: step 13, image 2 of 2
    • Remove the three switch covers.
    Ask FixBot
  14. Boss CE-300 Super Chorus Dial Replacement: step 14, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the single 7.8 mm screw on the left side of the bracket.
    • Repeat the previous bullet on the right side of the bracket.
    Ask FixBot
  15. Boss CE-300 Super Chorus Dial Replacement: step 15, image 1 of 2 Boss CE-300 Super Chorus Dial Replacement: step 15, image 2 of 2
    • Remove the two audio jacks that are to the side.
    • Do not pull the face bracket fully off and away. Some cables will remain attached to the face bracket and to the board.
    • Carefully remove the face bracket by sliding it forward until it clears all dials, then lift up.
    Ask FixBot
  16. Boss CE-300 Super Chorus Dial Replacement, Dial: step 16, image 1 of 2 Boss CE-300 Super Chorus Dial Replacement, Dial: step 16, image 2 of 2
    • Desolder the marked joints from the "top" of the board.
    • Some dials are labeled on the board to help identify what solder joints lead to what dial. Double check that you de-solder the correct joints.
    • The second picture demonstrates desoldering of the "chorus level" dial.
    • Remove the dials.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Haley Lansdon
628 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 15
All Time: 193
