Bose portable speaker battery Replacement
      • flip speaker over onto its back
      Ask FixBot
      • using a heat gun, soften the adhesive holding the ring in place.
      Ask FixBot
      • peel off the ring that covers the screws
      • using your screwdriver, undo the 4 screws that hold the base onto the body of the speaker.
      Ask FixBot
      • using your heat gun, apply a slight amount of heat to soften the adhesive.
      • during reassembly, apply the new adhesive.
      Ask FixBot
      • using your screwdriver, undo the 4 screws holding the speaker assembly in place.
      • carefully pry in the edge of the speaker assembly.
      • be very careful when prying as it is still connected to the motherboard wires.
      Ask FixBot
      • using a spludger, carefully disconnect the speaker cables from the motherboard.
      • be very careful not to damage the connector.
      Ask FixBot
      • using your spludger, carefully pry up the battery.
      • be very careful not to puncture the battery.
      Ask FixBot
      • using 2 fingers, pinch the connector connecting the battery and pull it straight out.
      Ask FixBot
776831
1,067 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 62
All Time: 945
