Bose Wave Radio AWR1-1W Screen Replacement
  1. Bose Wave Radio AWR1-1W Screen Replacement, Base: step 1, image 1 of 2 Bose Wave Radio AWR1-1W Screen Replacement, Base: step 1, image 2 of 2
    • Remove the four 19mm Phillips #2 screws from the base of the device.
    Ask FixBot
  2. Bose Wave Radio AWR1-1W Screen Replacement: step 2, image 1 of 3 Bose Wave Radio AWR1-1W Screen Replacement: step 2, image 2 of 3 Bose Wave Radio AWR1-1W Screen Replacement: step 2, image 3 of 3
    • Turn the device over, holding the base on with your thumbs.
    • Hold the device tightly to prevent the base from falling off.
    Ask FixBot
  3. Bose Wave Radio AWR1-1W Screen Replacement: step 3, image 1 of 3 Bose Wave Radio AWR1-1W Screen Replacement: step 3, image 2 of 3 Bose Wave Radio AWR1-1W Screen Replacement: step 3, image 3 of 3
    • Gently lift the top off of the device.
    • Lift in the direction shown to avoid damaging the wires connecting the top and base of the device.
    Ask FixBot
  4. Bose Wave Radio AWR1-1W Screen Replacement: step 4, image 1 of 3 Bose Wave Radio AWR1-1W Screen Replacement: step 4, image 2 of 3 Bose Wave Radio AWR1-1W Screen Replacement: step 4, image 3 of 3
    • Pinch and unplug the white connector from the device.
    Ask FixBot
  5. Bose Wave Radio AWR1-1W Screen Replacement: step 5, image 1 of 3 Bose Wave Radio AWR1-1W Screen Replacement: step 5, image 2 of 3 Bose Wave Radio AWR1-1W Screen Replacement: step 5, image 3 of 3
    • Gently pinch and pull on the white ribbon cable to disconnect it from the base.
    Ask FixBot
  6. Bose Wave Radio AWR1-1W Screen Replacement: step 6, image 1 of 1
    • The base should now be completely detached from the device.
    Ask FixBot
  7. Bose Wave Radio AWR1-1W Screen Replacement, Front Grill: step 7, image 1 of 3 Bose Wave Radio AWR1-1W Screen Replacement, Front Grill: step 7, image 2 of 3 Bose Wave Radio AWR1-1W Screen Replacement, Front Grill: step 7, image 3 of 3
    • Wedge the spudger between the top and front panel on the right side of the device.
    • Push down on the spudger, lifting the front panel away from the top panel until it pops out of the right side.
    • Repeat for the left side of the device.
    • Too much pressure may break the panel, but it should flex slightly before it pops out.
    Ask FixBot
  8. Bose Wave Radio AWR1-1W Screen Replacement: step 8, image 1 of 3 Bose Wave Radio AWR1-1W Screen Replacement: step 8, image 2 of 3 Bose Wave Radio AWR1-1W Screen Replacement: step 8, image 3 of 3
    • Once the panel is released on the left side, wedge the spudger between the top panel and front grill of the device as shown.
    • Apply pressure and move the spudger upward until the front grill pops out.
    • Repeat for the right side of the device.
    Ask FixBot
  9. Bose Wave Radio AWR1-1W Screen Replacement: step 9, image 1 of 1
    • Lift the front grill away from the device.
    Ask FixBot
  10. Bose Wave Radio AWR1-1W Screen Replacement, Button Panel: step 10, image 1 of 2 Bose Wave Radio AWR1-1W Screen Replacement, Button Panel: step 10, image 2 of 2
    • Turn the device around.
    • Wedge the spudger into the larger part of the gap under the back of the device.
    Ask FixBot
  11. Bose Wave Radio AWR1-1W Screen Replacement: step 11, image 1 of 1
    • Move the spudger up until the button panel is loose.
    • Push forward on the back of the button panel to disconnect the panel from the top of the device.
    Ask FixBot
  12. Bose Wave Radio AWR1-1W Screen Replacement: step 12, image 1 of 2 Bose Wave Radio AWR1-1W Screen Replacement: step 12, image 2 of 2
    • Pull the button panel forward with one hand and push the screen assembly into the device with the other to disconnect the button panel.
    Ask FixBot
  13. Bose Wave Radio AWR1-1W Screen Replacement, Screen: step 13, image 1 of 3 Bose Wave Radio AWR1-1W Screen Replacement, Screen: step 13, image 2 of 3 Bose Wave Radio AWR1-1W Screen Replacement, Screen: step 13, image 3 of 3
    • Gently pull the top of the screen assembly away from the device.
    Ask FixBot
  14. Bose Wave Radio AWR1-1W Screen Replacement: step 14, image 1 of 2 Bose Wave Radio AWR1-1W Screen Replacement: step 14, image 2 of 2
    • Lift the screen assembly upward and pull the white wire strip out of the device.
    Ask FixBot
4 other people completed this guide.
Cassie Harriman
1,041 Reputation
5 Guides authored
Cal Poly, Team S15-G2, Banghart Spring 2017 Member of Cal Poly, Team S15-G2, Banghart Spring 2017
CPSU-BANGHART-S17S15G2
4 Members
6 Guides authored
6 Guide Comments
Great! This device is the best wave system in sound accurate. All frequencies sounds clear!!! Awesome!!!
srmrs - Reply Share
Nicely done.  Love the details.  Just one question - where can I get the replacement screen?
Patsy Hamilton - Reply Share
Instructions were PERFECT! Thank you. I found my replacement screen on ebay for $25, took a chance that it would work as stated by the seller. Otherwise I would have thrown the radio away.
John Stine - Reply Share
I performed the repair as directed. It was easy especially if you have a plastic spung to work with. Problem comes from the new display once installed shows all the characters? Unplugged it and re-plugged but still stuck in all character test mode?
plhamp - Reply Share
How to purchase White wire strip
Bruce Ebneter - Reply Share
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 82
All Time: 12,708
