Bose Soundlink Revolve Bottom Circuit Board Replacement
    1. Bose Soundlink Revolve Bottom Circuit Board Replacement, Bottom Circuit Board Access: step 1, image 1 of 2 Bose Soundlink Revolve Bottom Circuit Board Replacement, Bottom Circuit Board Access: step 1, image 2 of 2
      • Flip speaker over so that the bottom is facing up.
      • Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
      Ask FixBot
    2. Bose Soundlink Revolve Bottom Circuit Board Replacement: step 2, image 1 of 3 Bose Soundlink Revolve Bottom Circuit Board Replacement: step 2, image 2 of 3 Bose Soundlink Revolve Bottom Circuit Board Replacement: step 2, image 3 of 3
      • Using the screwdriver, unscrew three screws.
      • Detach the bottom cover from the rest of the speaker by pulling the two in opposite directions.
      Ask FixBot
    3. Bose Soundlink Revolve Bottom Circuit Board Replacement: step 3, image 1 of 2 Bose Soundlink Revolve Bottom Circuit Board Replacement: step 3, image 2 of 2
      • Remove the screw that is above the charging port.
      Ask FixBot
    4. Bose Soundlink Revolve Bottom Circuit Board Replacement: step 4, image 1 of 2 Bose Soundlink Revolve Bottom Circuit Board Replacement: step 4, image 2 of 2
      • Remove the two screws connecting the motherboard to the bottom cover of the speaker.
      • Remove the bottom cover.
      Ask FixBot
    1. Bose Soundlink Revolve Bottom Circuit Board Replacement, AUX/USB Port: step 5, image 1 of 3 Bose Soundlink Revolve Bottom Circuit Board Replacement, AUX/USB Port: step 5, image 2 of 3 Bose Soundlink Revolve Bottom Circuit Board Replacement, AUX/USB Port: step 5, image 3 of 3
      • Using the blue plastic opening tool, pry up the small black clamp connecting the AUX/USB port to the lower circuit board.
      • Remove the AUX/USB port from the device.
      Ask FixBot
    1. Bose Soundlink Revolve Bottom Circuit Board Replacement, Bottom Circuit Board: step 6, image 1 of 1
      • Remove the yellow tape over the location where the ribbon from the central speaker meets the bottom circuit board.
      • Use the blue plastic opening tool to pry up the black latch holding down the ribbon.
      • Remove the motherboard from the device.
      Ask FixBot
7 other people completed this guide.
Brian Butner
927 Reputation
3 Guides authored
USF Tampa, Team S6-G2, Remmell Fall 2017 Member of USF Tampa, Team S6-G2, Remmell Fall 2017
USFT-REMMELL-F17S6G2
4 Members
12 Guides authored
43 Guide Comments
I need the ribbon because it is damage, can you sell one to me?
My email is ttegil@hotmail.com can you send me the way I can buy it.
Kind regards
Gilberto - Reply Share
Hello do toi fond thé ribbon because i have thé same problème .
M'y email adresse thualromain44.rt@gmail.com
Thanks you
romain thual - Reply Share
Hi I need bottom circuit board for bose revolve , could you sale it for me. mail: seawolf1974@mail.ru , delivery to Spain
kindly regards
seawolf1974 - Reply Share
I need bottom circuit board for Bose revolve, can I get it available in Nigeria, @sullivaniheme@gmail.com
Sullivan - Reply Share
Hey there, I also require the bottom circuit board for my Bose Revolve sam.rowlands@hotmail.com
Sam - Reply Share
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 132
All Time: 17,902
