Up to 20% off select tools
Bose Soundlink III Battery Replacement
Views: 74K
View statistics:
Past 24 Hours:
12
Past 7 Days:
118
Past 30 Days:
595
All Time:
74,260
Comments: 32
4 comments on steps, 28 guide comments.
Go to guide comments
Completed: 46
46 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
If your SoundLink III exhibits significantly decreased battery life or no longer takes a charge, you may need a new battery. In this guide, you will learn how to open up your Bose Soundlink III and replace the battery.
    1. Bose Soundlink III Battery Replacement, Battery: step 1, image 1 of 1
      • Use a spudger to pry the rubber pads off of the bottom panel of the SoundLink.
      • The rubber pads should have enough adhesive to stick when you reassemble them at the end. If not, however, you may need your own adhesive.
      Ask FixBot
    2. Bose Soundlink III Battery Replacement: step 2, image 1 of 2 Bose Soundlink III Battery Replacement: step 2, image 2 of 2
      • Remove the two 12.5 mm screws using a Phillips #2 screwdriver.
      • These screws may be difficult to remove. If necessary, use a lever for extra torque.
      • Remove the bottom panel.
      Ask FixBot
    3. Bose Soundlink III Battery Replacement: step 3, image 1 of 1
      • Flip the rear panel back to allow access to the SoundLink's battery.
      Ask FixBot
    4. Bose Soundlink III Battery Replacement: step 4, image 1 of 2 Bose Soundlink III Battery Replacement: step 4, image 2 of 2
      • Remove the two 12.5 mm Phillips #2 screws from the sides of the battery.
      Ask FixBot
46 other people completed this guide.
Author
with
Dakoda Sanders
1,705 Reputation
4 Guides authored
USF Tampa, Team 3-2, Wollert Spring 2016 Member of USF Tampa, Team 3-2, Wollert Spring 2016
USFT-WOLLERT-S16S3G2
4 Members
60 Guides authored
28 Guide Comments
Hello, I wonder where I could buy a raplacement battery for my Bose Soundlink III. (I'm from Belgium)
Thanks for the response.
Gabriel Lohest - Reply Share
Gabriel, ik heb Bose gecontacteerd en ze zeggen dat ze dat niet apart verkopen. Het enigste wat ik heb gevonden is dit:http://www.ecrater.com/p/25268626/batter...
Of als het nog onder garantie valt, gewoon terug opsturen.
Gabrial, I've contacted Bose and they say that they didn't sell them seperately. The only thing that I've found is this:http://www.ecrater.com/p/25268626/batter...
If it still falls under warranty, send the speaker back.
JJ Hu - Reply Share
yea i'm also interested to buy bose soundlink 3 battery hurmmm where could i get it....
Admin Fluffy - Reply Share
Yes please, where do you get replacement batteries (I'm from Australia and Bose here want to charge me $149 to remove and replace 4 screws!)
Bob Mandassa - Reply Share
I want to buy also. I'm here in Saudi arabia dammam
alphamendoza5 - Reply Share
Past 24 Hours: 12
Past 7 Days: 118
Past 30 Days: 595
All Time: 74,260
