Up to 20% off select tools
Bose Soundlink II Side Cover Replacement
Views: 3.8K
View statistics:
Past 24 Hours:
5
Past 7 Days:
28
Past 30 Days:
126
All Time:
3,795
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 8 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The Bose Soundlink II is a compact Bluetooth speaker requiring substantial disassembly in order to access the components of the device. The side covers are easy to remove if the location of the necessary screws is known.
    1. Bose Soundlink II Side Cover Replacement, Bose Soundlink II Cover Removal: step 1, image 1 of 1
      • Using a 2.5 mm hex wrench, remove the two 13 mm screws from the bottom of the speaker.
      Ask FixBot
    2. Bose Soundlink II Side Cover Replacement: step 2, image 1 of 1
      • Push up on the back of the cover until it slides up slightly.
      • Pull the cover up and away from the speaker backing.
      Ask FixBot
    1. Bose Soundlink II Side Cover Replacement, Side Cover: step 3, image 1 of 1
      • Remove the black electrical tape in order to reveal the screws attaching the side cover to the main body of the speaker. These screws are on the base of the device.
      Ask FixBot
    2. Bose Soundlink II Side Cover Replacement: step 4, image 1 of 1
      • Using the T-10 star tip screwdriver, remove the two 13 mm screws located on the bottom of the speaker on each side of the battery pack.
      Ask FixBot
    3. Bose Soundlink II Side Cover Replacement: step 5, image 1 of 3 Bose Soundlink II Side Cover Replacement: step 5, image 2 of 3 Bose Soundlink II Side Cover Replacement: step 5, image 3 of 3
      • Slide the silver side cover down toward the base of the speaker. The silver cover will come off easily.
      Ask FixBot
4 other people completed this guide.
Author
with
John P Loughran
472 Reputation
3 Guides authored
IUPUI, Team S3-G3, Harley Spring 2017 Member of IUPUI, Team S3-G3, Harley Spring 2017
IUPUI-HARLEY-S17S3G3
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 126
All Time: 3,795
