Tools
Introduction
Go to step 1 ↓The button covers for the Bose Soundlink II require substantial disassembly of the device. The button cover is difficult to remove and easy to break. Be careful!
Using a 2.5 mm hex wrench, remove the two 13 mm screws from the bottom of the speaker.
Remove the black electrical tape in order to reveal the screws attaching the side cover to the main body of the speaker. These screws are on the base of the device.
Once the Bose Soundlink II Side Covers Removal has been completed, remove the two screws (13 mm) an inch below the buttons on the back of the speaker using the T-10 star tip screwdriver.
Using a tool such as a spudger or plastic opening tool, insert the end into one of the small indentations located on the back of the speaker. Start either on the indentation farthest to the right or to the left.
Pry up with the spudger or plastic opening tool so that the cover is pushed up slightly.
2 other people completed this guide.
