Bose Soundlink Flex Radiator Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
34
Past 30 Days:
148
All Time:
1,239
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The radiator on the Bose Soundlink Flex is what allows the speaker to have bass in the music. It works by using sound pressure to create deep pitches in music otherwise known as baselines. If the speaker seems to have little to no bass all of a sudden and the device is clean this may mean that the radiator is damaged and needs replacing. The radiator has two parts: one is attached next to the motherboard and the other is attached to the black back panel. Follow this guide to see how to replace the radiators.
Parts
Tools
    1. Bose Soundlink Flex Radiator Replacement, Grille: step 1, image 1 of 1
      • Use a heat gun to warm up the device.
      • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
      Ask FixBot
    2. Bose Soundlink Flex Radiator Replacement: step 2, image 1 of 1
      • Use an iFixit opening tool to pop off the eight clips on the grille.
      • Be patient and do not rush this process as you may otherwise damage the device.
      Ask FixBot
    3. Bose Soundlink Flex Radiator Replacement: step 3, image 1 of 2 Bose Soundlink Flex Radiator Replacement: step 3, image 2 of 2
      • Once the clips have been released, the only thing holding the grille on is glue.
      • Apply minimal force and the grille should pop right off the device.
      • Reheat the device to warm up the glue if there is difficulty in removing.
      Ask FixBot
    1. Bose Soundlink Flex Radiator Replacement, Radiator: step 4, image 1 of 3 Bose Soundlink Flex Radiator Replacement, Radiator: step 4, image 2 of 3 Bose Soundlink Flex Radiator Replacement, Radiator: step 4, image 3 of 3
      • Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
      • Lift the driver out, being cautious of the wires still connected to the device.
      Ask FixBot
    2. Bose Soundlink Flex Radiator Replacement: step 5, image 1 of 2 Bose Soundlink Flex Radiator Replacement: step 5, image 2 of 2
      • Remove the six 2.3 mm screws around the edge with a TR8 Torx screwdriver.
      Ask FixBot
    3. Bose Soundlink Flex Radiator Replacement: step 6, image 1 of 3 Bose Soundlink Flex Radiator Replacement: step 6, image 2 of 3 Bose Soundlink Flex Radiator Replacement: step 6, image 3 of 3
      • Pull the backplate off to expose both sides of the radiator.
      Ask FixBot
    4. Bose Soundlink Flex Radiator Replacement: step 7, image 1 of 3 Bose Soundlink Flex Radiator Replacement: step 7, image 2 of 3 Bose Soundlink Flex Radiator Replacement: step 7, image 3 of 3
      • Remove the four 2.3 mm corner screws using a TR8 Torx screwdriver.
      • Remove the two 1.7 mm screws using a TR6 Torx screwdriver.
      • Follow this step for both radiators.
      Ask FixBot
    5. Bose Soundlink Flex Radiator Replacement: step 8, image 1 of 2 Bose Soundlink Flex Radiator Replacement: step 8, image 2 of 2
      • Remove the radiator and replace with the new radiator.
      Ask FixBot
Monica Silva
262 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 34
Past 30 Days: 148
All Time: 1,239
