Bose Soundlink Flex Grille Replacement
    1. Bose Soundlink Flex Grille Replacement, Grille: step 1, image 1 of 1
      • Use a heat gun to warm up the device.
      • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
      Ask FixBot
    2. Bose Soundlink Flex Grille Replacement: step 2, image 1 of 1
      • Use an iFixit opening tool to pop off the eight clips on the grille.
      • Be patient and do not rush this process as you may otherwise damage the device.
      Ask FixBot
    3. Bose Soundlink Flex Grille Replacement: step 3, image 1 of 2 Bose Soundlink Flex Grille Replacement: step 3, image 2 of 2
      • Once the clips have been released, the only thing holding the grille on is glue.
      • Apply minimal force and the grille should pop right off the device.
      • Reheat the device to warm up the glue if there is difficulty in removing.
      Ask FixBot
Isaac
223 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 10
Past 30 Days: 74
All Time: 1,095
