Up to 20% off select tools
Bose Soundlink Flex Driver Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
8
Past 7 Days:
43
Past 30 Days:
183
All Time:
2,479
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
A common issue with the Bose Soundlink Flex is its speaker. Over time, wear and tear degrade the quality of the sound the speaker produces. This guide will provide the necessary steps in replacing this component. If the speaker is in good condition, but the audio is not playing, be sure to check the Bluetooth connnection and reboot if necessary. If the Bluetooth is not working, be sure the speaker is turned on and in pair mode by going into the device settings on the device you wish to pair.
    1. Bose Soundlink Flex Driver Replacement, Grille: step 1, image 1 of 1
      • Use a heat gun to warm up the device.
      • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
      Ask FixBot
    2. Bose Soundlink Flex Driver Replacement: step 2, image 1 of 1
      • Use an iFixit opening tool to pop off the eight clips on the grille.
      • Be patient and do not rush this process as you may otherwise damage the device.
      Ask FixBot
    3. Bose Soundlink Flex Driver Replacement: step 3, image 1 of 2 Bose Soundlink Flex Driver Replacement: step 3, image 2 of 2
      • Once the clips have been released, the only thing holding the grille on is glue.
      • Apply minimal force and the grille should pop right off the device.
      • Reheat the device to warm up the glue if there is difficulty in removing.
      Ask FixBot
    1. Bose Soundlink Flex Driver Replacement, Driver: step 4, image 1 of 3 Bose Soundlink Flex Driver Replacement, Driver: step 4, image 2 of 3 Bose Soundlink Flex Driver Replacement, Driver: step 4, image 3 of 3
      • Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
      • Lift the driver out, being cautious of the wires still connected to the device.
      Ask FixBot
    2. Bose Soundlink Flex Driver Replacement: step 5, image 1 of 3 Bose Soundlink Flex Driver Replacement: step 5, image 2 of 3 Bose Soundlink Flex Driver Replacement: step 5, image 3 of 3
      • Remove the six 2.3 mm screws around the edge with a TR8 Torx screwdriver.
      • Pull the back panel off exposing the motherboard.
      Ask FixBot
    3. Bose Soundlink Flex Driver Replacement: step 6, image 1 of 2 Bose Soundlink Flex Driver Replacement: step 6, image 2 of 2
      • Desolder the joints that are connecting the speaker to the motherboard.
      • Solder the new speaker with the wire color in the same order.
      • Be cautious when removing and adding the solder to not damage the motherboard or burn yourself.
      Ask FixBot
Author
with
Kalvin Lee
625 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 43
Past 30 Days: 183
All Time: 2,479
