Bose Soundlink Flex Charging Port Replacement
  1. Bose Soundlink Flex Charging Port Replacement, Grille: step 1, image 1 of 1
    • Use a heat gun to warm up the device.
    • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
    Ask FixBot
  2. Bose Soundlink Flex Charging Port Replacement: step 2, image 1 of 1
    • Use an iFixit opening tool to pop off the eight clips on the grille.
    • Be patient and do not rush this process as you may otherwise damage the device.
    Ask FixBot
  3. Bose Soundlink Flex Charging Port Replacement: step 3, image 1 of 2 Bose Soundlink Flex Charging Port Replacement: step 3, image 2 of 2
    • Once the clips have been released, the only thing holding the grille on is glue.
    • Apply minimal force and the grille should pop right off the device.
    • Reheat the device to warm up the glue if there is difficulty in removing.
    Ask FixBot
  4. Bose Soundlink Flex Charging Port Replacement, Charging Port: step 4, image 1 of 3 Bose Soundlink Flex Charging Port Replacement, Charging Port: step 4, image 2 of 3 Bose Soundlink Flex Charging Port Replacement, Charging Port: step 4, image 3 of 3
    • Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
    • Lift the driver out, being cautious of the wires still connected to the device.
    Ask FixBot
  5. Bose Soundlink Flex Charging Port Replacement: step 5, image 1 of 3 Bose Soundlink Flex Charging Port Replacement: step 5, image 2 of 3 Bose Soundlink Flex Charging Port Replacement: step 5, image 3 of 3
    • Remove the six 2.3 mm screws around the edge with a TR8 Torx screwdriver.
    • Pull the back panel off exposing the motherboard.
    Ask FixBot
  6. Bose Soundlink Flex Charging Port Replacement: step 6, image 1 of 2 Bose Soundlink Flex Charging Port Replacement: step 6, image 2 of 2
    • Remove the three 1.7 mm screws from the motherboard using a TR6 Torx screwdriver.
    • Remove the single 1.4 mm screw from the motherboard using a TR5 Torx screwdriver.
    Ask FixBot
  7. Bose Soundlink Flex Charging Port Replacement: step 7, image 1 of 2 Bose Soundlink Flex Charging Port Replacement: step 7, image 2 of 2
    • Remove the motherboard by sliding the charging port out of the case.
    Ask FixBot
8 other people completed this guide.
Kalvin Lee
625 Reputation
3 Guides authored
7 Guide Comments
Where did you get the port from ?
asdrubalaburto - Reply Share
Can we get the link to the charging port so I can purchase one? Mine fell and broke while charging. Appreciate the instructions.Thanks in advance for the link
Wins - Reply Share
Rather than replacing the port on the motherboard, I will use a Female USB-C to wire power cable, run it through the hole, and seal it with hot glue, so I will not have to repeat this process. But many thanks for the "way in." so to speak.
James - Reply Share
Where is Step 8 and/or other steps?
Jaimie Santiago - Reply Share
Does anyone have a source for the port? Is replacing the m/b the only way other than directly soldering a charging cable?
Adam Yavner - Reply Share
Past 24 Hours: 9
Past 7 Days: 72
Past 30 Days: 359
All Time: 4,650
