Up to 20% off select tools
Bose Soundlink Flex Battery Replacement
Views: 10K
View statistics:
Past 24 Hours:
18
Past 7 Days:
164
Past 30 Days:
569
All Time:
10,454
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Having trouble turning your speaker on? Then you probably need to replace the battery. This guide will show you how to properly replace the battery of the Bose Soundlink Flex speaker. Otherwise, the speaker's battery may be dead; it takes around 4 hours to charge to 100%.
    1. Bose Soundlink Flex Battery Replacement, Grille: step 1, image 1 of 1
      • Use a heat gun to warm up the device.
      • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
      Ask FixBot
    2. Bose Soundlink Flex Battery Replacement: step 2, image 1 of 1
      • Use an iFixit opening tool to pop off the eight clips on the grille.
      • Be patient and do not rush this process as you may otherwise damage the device.
      Ask FixBot
    3. Bose Soundlink Flex Battery Replacement: step 3, image 1 of 2 Bose Soundlink Flex Battery Replacement: step 3, image 2 of 2
      • Once the clips have been released, the only thing holding the grille on is glue.
      • Apply minimal force and the grille should pop right off the device.
      • Reheat the device to warm up the glue if there is difficulty in removing.
      Ask FixBot
    1. Bose Soundlink Flex Battery Replacement, Battery: step 4, image 1 of 3 Bose Soundlink Flex Battery Replacement, Battery: step 4, image 2 of 3 Bose Soundlink Flex Battery Replacement, Battery: step 4, image 3 of 3
      • Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
      • Lift the driver out, being cautious of the wires still connected to the device.
      Ask FixBot
    2. Bose Soundlink Flex Battery Replacement: step 5, image 1 of 3 Bose Soundlink Flex Battery Replacement: step 5, image 2 of 3 Bose Soundlink Flex Battery Replacement: step 5, image 3 of 3
      • Remove the six 2.3 mm screws around the edge with a TR8 Torx screwdriver.
      • Pull the back panel off exposing the motherboard.
      Ask FixBot
    3. Bose Soundlink Flex Battery Replacement: step 6, image 1 of 2 Bose Soundlink Flex Battery Replacement: step 6, image 2 of 2
      • Remove the three 1.7 mm screws from the motherboard using a TR6 Torx screwdriver.
      • Remove the single 1.4 mm screw from the motherboard using a TR5 Torx screwdriver.
      Ask FixBot
    4. Bose Soundlink Flex Battery Replacement: step 7, image 1 of 3 Bose Soundlink Flex Battery Replacement: step 7, image 2 of 3 Bose Soundlink Flex Battery Replacement: step 7, image 3 of 3
      • Take the motherboard out and take note of the battery attached.
      • Remove the insulation and the solder from the wiring.
      • Be careful not to damage the motherboard. Doing so will create a slew of problems for the speaker.
      • Solder the wires of the new battery onto the motherboard.
      • Be cautious when adding the solder to not damage the motherboard or burn yourself.
      Ask FixBot
6 other people completed this guide.
Author
with
Kalvin Lee
625 Reputation
3 Guides authored
1 Guide Comment
How do I know which one is the positive and which one is the negative side of my battery connector in soundlink flex ? As I have already removed the old battery only.
SOM SATPATHY - Reply Share
Past 24 Hours: 18
Past 7 Days: 164
Past 30 Days: 569
All Time: 10,454
