Up to 20% off select tools
Bose SoundTouch Portable Subwoofer Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
109
All Time:
2,227
Comments: 5
3 comments on steps, 2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 35 minutes
Difficulty: Moderate
Student In Progress
This guide is being worked on by hardworking students.
Tools
    1. Bose SoundTouch Portable Subwoofer Replacement, Speaker Battery: step 1, image 1 of 1
      • Remove the two T-10 machine screws at the bottom of the device.
      Ask FixBot
    2. Bose SoundTouch Portable Subwoofer Replacement: step 2, image 1 of 1
      • Turn the device around.
      • From the top, lightly push down the back cover to release it.
      • Lift the bottom of the cover and pull it up.
      Ask FixBot
    3. Bose SoundTouch Portable Subwoofer Replacement: step 3, image 1 of 1
      • Remove the two T-10 machine screws, then pull the battery straight out.
      Ask FixBot
    1. Bose SoundTouch Portable Subwoofer Replacement, Grille: step 4, image 1 of 1
      • Remove the two screws holding the speaker grille in place.
      Ask FixBot
    2. Bose SoundTouch Portable Subwoofer Replacement: step 5, image 1 of 1
      • Grip the sides of the device and push the speaker grille down and out.
      Ask FixBot
    3. Bose SoundTouch Portable Subwoofer Replacement: step 6, image 1 of 1
      • Gently release the ribbon from its connector and remove the grille.
      Ask FixBot
    1. Bose SoundTouch Portable Subwoofer Replacement, Metal Trim: step 7, image 1 of 1
      • Remove the two screws using a torx screwdriver.
      Ask FixBot
    2. Bose SoundTouch Portable Subwoofer Replacement: step 8, image 1 of 1
      • With the bottom of the device facing you, pull down the trim pieces to remove from the device body.
      Ask FixBot
    1. Bose SoundTouch Portable Subwoofer Replacement, Subwoofer: step 9, image 1 of 2 Bose SoundTouch Portable Subwoofer Replacement, Subwoofer: step 9, image 2 of 2
      • Separate the case that holds the subwoofer in place.
      • Be careful when doing this step because there are several connectors inside.
      Ask FixBot
    2. Bose SoundTouch Portable Subwoofer Replacement: step 10, image 1 of 1
      • Gently pull on the connectors at the circuit board to remove. Remove the screws from the circuit board and set the board aside.
      Ask FixBot
    3. Bose SoundTouch Portable Subwoofer Replacement: step 11, image 1 of 3 Bose SoundTouch Portable Subwoofer Replacement: step 11, image 2 of 3 Bose SoundTouch Portable Subwoofer Replacement: step 11, image 3 of 3
      • Remove the four screws from the subwoofer and lift it out of the casing.
      Ask FixBot
Author
with
Chelsea Martin
706 Reputation
6 Guides authored
USF Tampa, Team S1-G3, Leahy Spring 2017 Member of USF Tampa, Team S1-G3, Leahy Spring 2017
USFT-LEAHY-S17S1G3
3 Members
108 Guides authored
2 Guide Comments
Thanks a lot for sharing your incredible ideas. It is an appreciated and pretty tip for all those music lovers. What a Fatal post for those who want to upgrade an existing subwoofer with a new one.
About more: www.outdoorsumo.com
Outdoor Sumo - Reply Share
About more: ++https://compactcarsubwoofer.blogspot.com...
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 109
All Time: 2,227
