Bose SoundTouch Portable Speaker Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
104
All Time:
2,536
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This tutorial requires removal of the front grille and back cover to access the speakers.
Tools
    1. Bose SoundTouch Portable Speaker Replacement, Speaker Battery: step 1, image 1 of 1
      • Remove the two T-10 machine screws at the bottom of the device.
      Ask FixBot
    2. Bose SoundTouch Portable Speaker Replacement: step 2, image 1 of 1
      • Turn the device around.
      • From the top, lightly push down the back cover to release it.
      • Lift the bottom of the cover and pull it up.
      Ask FixBot
    3. Bose SoundTouch Portable Speaker Replacement: step 3, image 1 of 1
      • Remove the two T-10 machine screws, then pull the battery straight out.
      Ask FixBot
    1. Bose SoundTouch Portable Speaker Replacement, Grille: step 4, image 1 of 1
      • Remove the two screws holding the speaker grille in place.
      Ask FixBot
    2. Bose SoundTouch Portable Speaker Replacement: step 5, image 1 of 1
      • Grip the sides of the device and push the speaker grille down and out.
      Ask FixBot
    3. Bose SoundTouch Portable Speaker Replacement: step 6, image 1 of 1
      • Gently release the ribbon from its connector and remove the grille.
      Ask FixBot
    1. Bose SoundTouch Portable Speaker Replacement, Speakers: step 7, image 1 of 1
      • There are four T-10 Torx screws for each speaker; remove all four screws for each speaker you are replacing.
      Ask FixBot
    2. Bose SoundTouch Portable Speaker Replacement: step 8, image 1 of 3 Bose SoundTouch Portable Speaker Replacement: step 8, image 2 of 3 Bose SoundTouch Portable Speaker Replacement: step 8, image 3 of 3
      • Using a plastic pry tool, carefully pry the speaker up.
      • With the bottom of the speaker exposed, unwind the wires from the connection tabs and replace the speaker.
      Ask FixBot
Chelsea Martin
706 Reputation
6 Guides authored
USF Tampa, Team S1-G3, Leahy Spring 2017 Member of USF Tampa, Team S1-G3, Leahy Spring 2017
USFT-LEAHY-S17S1G3
3 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 104
All Time: 2,536
