Bose SoundTouch Portable Motherboard Replacement
    1. Bose SoundTouch Portable Motherboard Replacement, Speaker Battery: step 1, image 1 of 1
      • Remove the two T-10 machine screws at the bottom of the device.
      Ask FixBot
    2. Bose SoundTouch Portable Motherboard Replacement: step 2, image 1 of 1
      • Turn the device around.
      • From the top, lightly push down the back cover to release it.
      • Lift the bottom of the cover and pull it up.
      Ask FixBot
    3. Bose SoundTouch Portable Motherboard Replacement: step 3, image 1 of 1
      • Remove the two T-10 machine screws, then pull the battery straight out.
      Ask FixBot
    1. Bose SoundTouch Portable Motherboard Replacement, Metal Trim: step 4, image 1 of 1
      • Remove the two screws using a torx screwdriver.
      Ask FixBot
    2. Bose SoundTouch Portable Motherboard Replacement: step 5, image 1 of 1
      • With the bottom of the device facing you, pull down the trim pieces to remove from the device body.
      Ask FixBot
    1. Bose SoundTouch Portable Motherboard Replacement, Motherboard: step 6, image 1 of 2 Bose SoundTouch Portable Motherboard Replacement, Motherboard: step 6, image 2 of 2
      • Remove four T-10 Torx screws; there are two on the front and two on the back.
      Ask FixBot
    2. Bose SoundTouch Portable Motherboard Replacement: step 7, image 1 of 3 Bose SoundTouch Portable Motherboard Replacement: step 7, image 2 of 3 Bose SoundTouch Portable Motherboard Replacement: step 7, image 3 of 3
      • Pinch and remove the connectors.
      • Use a flat tool to pry off the top piece.
      Ask FixBot
    3. Bose SoundTouch Portable Motherboard Replacement: step 8, image 1 of 3 Bose SoundTouch Portable Motherboard Replacement: step 8, image 2 of 3 Bose SoundTouch Portable Motherboard Replacement: step 8, image 3 of 3
      • Remove the four T-10 Torx screws holding the plastic cover in place.
      • Remove the one T-10 Torx screw that is holding the motherboard in place.
      • Pry off the motherboard.
      Ask FixBot
3 other people completed this guide.
Chelsea Martin
706 Reputation
6 Guides authored
USF Tampa, Team S1-G3, Leahy Spring 2017 Member of USF Tampa, Team S1-G3, Leahy Spring 2017
USFT-LEAHY-S17S1G3
3 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 46
All Time: 3,825
