Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓Use this guide to replace the screen on the front of your device.
Remove the (6) six 1.5 cm Phillips screws holding on the bottom cover of the speaker using a Phillips #0 screwdriver.
Lift the cover straight up and set the cover to the side.
Remove the (2) two 1.5 cm screws circled in picture one.
Rotate the speaker to its side and remove the (2) two 1.5 cm screws circled in picture 2. Remove these screws on either side of the speaker.
After all screws are removed, gently remove the cover from the speaker as shown in picture 3.
4 other people completed this guide.
