Bose SoundTouch 10 Charging Port Replacement
    1. Bose SoundTouch 10 Charging Port Replacement, Front Panel: step 1, image 1 of 1
      • Turn the speaker over so that the rubber strips along the bottom are facing you.
      • Use the iFixit Opening Tool to peel back the rubber strip on the bottom-front edge.
      Ask FixBot
    2. Bose SoundTouch 10 Charging Port Replacement: step 2, image 1 of 1
      • Use a #2 Phillips screwdriver to remove each of the three 20mm screws on the bottom front edge of the speaker.
      Ask FixBot
    3. Bose SoundTouch 10 Charging Port Replacement: step 3, image 1 of 2 Bose SoundTouch 10 Charging Port Replacement: step 3, image 2 of 2
      • Slide the front panel with the mesh covering downwards to disconnect it from the SoundTouch 10 body.
      • Lift the panel away to reveal the speaker head.
      Ask FixBot
    1. Bose SoundTouch 10 Charging Port Replacement, Back panel: step 4, image 1 of 1
      • Use a #2 Phillips screwdriver to remove each of the six 20mm screws located underneath the front panel.
      Ask FixBot
    2. Bose SoundTouch 10 Charging Port Replacement: step 5, image 1 of 1
      • Flip the speaker onto its back.
      • Loosen the adhesive by sliding a Metal Spudger under the edge where the back panel meets the speaker's body.
      Ask FixBot
    3. Bose SoundTouch 10 Charging Port Replacement: step 6, image 1 of 2 Bose SoundTouch 10 Charging Port Replacement: step 6, image 2 of 2
      • Use force with an iFixit Plastic Opening Tool to pry the back panel up from the speaker frame.
      • If the panel does not come free easily, a heat gun may be needed to weaken the adhesive.
      • Once the panel has been disconnected, it should fall open revealing the motherboard.
      Ask FixBot
    4. Bose SoundTouch 10 Charging Port Replacement: step 7, image 1 of 2 Bose SoundTouch 10 Charging Port Replacement: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Use ESD Safe Tweezers (Blunt Nose) to pull out the wire ribbon at the end of the motherboard.
      Ask FixBot
    5. Bose SoundTouch 10 Charging Port Replacement: step 8, image 1 of 2 Bose SoundTouch 10 Charging Port Replacement: step 8, image 2 of 2
      • The motherboard contains capacitors (shown as cylinders in the upper right of the picture) which can hold a charge even when the speaker is powered off. Do not touch them as doing so may result in a shock.
      • Pull up on the base of the speaker wire plug to disconnect it from the motherboard.
      Ask FixBot
    1. Bose SoundTouch 10 Charging Port Replacement, Bass Port: step 9, image 1 of 1
      • Use a #0 Phillips screwdriver to remove each of the two 11mm screws attached to the bass port.
      Ask FixBot
    2. Bose SoundTouch 10 Charging Port Replacement: step 10, image 1 of 1
      • Lift the bass port away from the motherboard.
      Ask FixBot
    1. Bose SoundTouch 10 Charging Port Replacement, Charging Port: step 11, image 1 of 2 Bose SoundTouch 10 Charging Port Replacement, Charging Port: step 11, image 2 of 2
      • Pinch the tab on the bottom of the clip connecting the charging port cables to the motherboard.
      • Lift upwards to disconnect the clip.
      Ask FixBot
    2. Bose SoundTouch 10 Charging Port Replacement: step 12, image 1 of 1
      • Use a #2 Phillips screwdriver to remove the two 15mm screws from either side of the charging port.
      Ask FixBot
    3. Bose SoundTouch 10 Charging Port Replacement: step 13, image 1 of 1
      • With an iFixit Plastic Opening Tool, pry the speaker port upwards and away from the socket.
      Ask FixBot
2 other people completed this guide.
James Asbury
952 Reputation
5 Guides authored
Cal Poly, Team S13-G1, Forte Spring 2017 Member of Cal Poly, Team S13-G1, Forte Spring 2017
CPSU-FORTE-S17S13G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 47
All Time: 6,005
