Bose SoundLink Mini Front/Back Protective Grille Replacement
    1. Bose SoundLink Mini Front/Back Protective Grille Replacement, Front/Back Protective Grille: step 1, image 1 of 1
      • Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
      • Place Metal Spudger in the location shown.
      Ask FixBot
    2. Bose SoundLink Mini Front/Back Protective Grille Replacement: step 2, image 1 of 2 Bose SoundLink Mini Front/Back Protective Grille Replacement: step 2, image 2 of 2
      • Slowly pry up the grille until the two tabs shown pop out.
      • Be very gentle, the grille will bend.
      Ask FixBot
    3. Bose SoundLink Mini Front/Back Protective Grille Replacement: step 3, image 1 of 2 Bose SoundLink Mini Front/Back Protective Grille Replacement: step 3, image 2 of 2
      • The grille is attached to the speaker with double sided sticky tape. To remove the grill gently pull upward while keeping tension to the right.
      Ask FixBot
    4. Bose SoundLink Mini Front/Back Protective Grille Replacement: step 4, image 1 of 2 Bose SoundLink Mini Front/Back Protective Grille Replacement: step 4, image 2 of 2
      • Repeat steps to remove the back grille.
      Ask FixBot
10 other people completed this guide.
Jordan Smith
946 Reputation
4 Guides authored
Cal Poly, Team 1-23, Maness Fall 2015 Member of Cal Poly, Team 1-23, Maness Fall 2015
CPSU-MANESS-F15S1G23
4 Members
60 Guides authored
7 Guide Comments
Has anyone an idea where to buy new meshs for the dark version of Bose SL II ? My are badly scratched and I'd like to replace them.. dont know where to buy them though..
krisskuli - Reply Share
Hi brilliant advise. Where can I get hold of the front perl white grill? I can't find it anywhere!
Peter Bacher - Reply Share
Hi brilliant advise. Where can I get hold of the front perl white grill of my soundlink mini ? I can't find it anywhere!
Where can I purchase the grill?
Ronald Roden Jr - Reply Share
Take out the grills, put a peace of tape on logo properly cut it, and repaint it. Apply a thin coat of spray paint only.
Pranjal Vishwakarma - Reply Share
Past 24 Hours: 6
Past 7 Days: 28
Past 30 Days: 132
All Time: 16,168
