Up to 20% off select tools
Bose SoundLink Mini Battery Cover Replacement
Views: 22K
View statistics:
Past 24 Hours:
10
Past 7 Days:
68
Past 30 Days:
300
All Time:
22,030
Comments: 24
21 comments on steps, 3 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Parts
Tools
  • TR8 Torx Security Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
The battery cover is the rubber flap on the bottom of the speaker that covers the battery. It cannot be pulled off without first going through several prerequisite steps. This guide will provide you with easy to follow steps to remove the battery cover on the Bose SoundLink Mini speaker.
    1. Bose SoundLink Mini Battery Cover Replacement, Battery: step 1, image 1 of 1
      • Peel back the rubber battery cover and remove the four circled 6.0 mm screws using a T8 Torx Screwdriver.
      Ask FixBot
    2. Bose SoundLink Mini Battery Cover Replacement: step 2, image 1 of 2 Bose SoundLink Mini Battery Cover Replacement: step 2, image 2 of 2
      • While holding the cover back, pull straight up on the battery to remove it.
      Ask FixBot
    1. Bose SoundLink Mini Battery Cover Replacement, Front/Back Protective Grille: step 3, image 1 of 1
      • Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
      • Place Metal Spudger in the location shown.
      Ask FixBot
    2. Bose SoundLink Mini Battery Cover Replacement: step 4, image 1 of 2 Bose SoundLink Mini Battery Cover Replacement: step 4, image 2 of 2
      • Slowly pry up the grille until the two tabs shown pop out.
      • Be very gentle, the grille will bend.
      Ask FixBot
    3. Bose SoundLink Mini Battery Cover Replacement: step 5, image 1 of 2 Bose SoundLink Mini Battery Cover Replacement: step 5, image 2 of 2
      • The grille is attached to the speaker with double sided sticky tape. To remove the grill gently pull upward while keeping tension to the right.
      Ask FixBot
    4. Bose SoundLink Mini Battery Cover Replacement: step 6, image 1 of 2 Bose SoundLink Mini Battery Cover Replacement: step 6, image 2 of 2
      • Repeat steps to remove the back grille.
      Ask FixBot
    1. Bose SoundLink Mini Battery Cover Replacement, Battery Cover: step 7, image 1 of 2 Bose SoundLink Mini Battery Cover Replacement, Battery Cover: step 7, image 2 of 2
      • Remove the four 15.0 mm screws on the left and the four 9.0 mm screws on the right using the T8 Torx Screwdriver.
      Ask FixBot
    2. Bose SoundLink Mini Battery Cover Replacement: step 8, image 1 of 2 Bose SoundLink Mini Battery Cover Replacement: step 8, image 2 of 2
      • Remove the circuit board by pushing it with your index finger in the direction shown while using a nylon or metal spudger to lift it up and out of place.
      Ask FixBot
    3. Bose SoundLink Mini Battery Cover Replacement: step 9, image 1 of 2 Bose SoundLink Mini Battery Cover Replacement: step 9, image 2 of 2
      • Carefully pull on the battery cover until the rubber tab slides out of the aluminum casing.
      Ask FixBot
8 other people completed this guide.
Author
with
Jordan Smith
946 Reputation
4 Guides authored
Cal Poly, Team 1-23, Maness Fall 2015 Member of Cal Poly, Team 1-23, Maness Fall 2015
CPSU-MANESS-F15S1G23
4 Members
60 Guides authored
3 Guide Comments
can someone tell me how do i reattach the rubber battery cover if i have removed it completely
rajpotus - Reply Share
Cut the lip off. You will not be able to put it back. It’s Bose’s terrible design.
megaspeed - Reply Share
@rajpotus: I had the same problem. If the little rubber tab is not damaged (mine was fine), you should be able to follow these instructions to replace it. But I have these comments on the instructions:
1) You do NOT need to remove the front grill. I have no idea why they suggest you do that here.
2) I think the reason you remove the battery is to make sure the circuit board has zero power on it when you work on it — otherwise a touch of the screwdriver to an unlucky spot on the board might short/burn something out. But I don’t think there’s any mechanical reason to remove it.
3) Once you pop off the back grill cover, you should be able to slide the tab through the slot and coax it up (maybe with a tooth-pick and/or tweezers) on top of the circuit board, but it’s probably better to unscrew the circuit board (as directed here) which makes it easier to push the rubber tab through. Then slide the circuit board back under the tab and screw it back into place.
Matthew Busche - Reply Share
Past 24 Hours: 10
Past 7 Days: 68
Past 30 Days: 300
All Time: 22,030
