Bose SoundLink Color Speaker Replacement
    1. Bose SoundLink Color Speaker Replacement, Outer Casing: step 1, image 1 of 2 Bose SoundLink Color Speaker Replacement, Outer Casing: step 1, image 2 of 2
      • Four round, plastic plugs are located on the back of the device.
      • Using a metal spudger, carefully pry up the plastic covers.
      • The covers are all glued on, so be careful not to scar the casing when prying them off. If possible, use a spudger or plastic opening tool to remove them.
      Ask FixBot
    2. Bose SoundLink Color Speaker Replacement: step 2, image 1 of 2 Bose SoundLink Color Speaker Replacement: step 2, image 2 of 2
      • Remove the four 1.8 cm-long T15 Torx Security screws from the outer case.
      • Some of these use T15 "Star" 5-point Torx security screws instead of the more common 6-point ones.
      Ask FixBot
    3. Bose SoundLink Color Speaker Replacement: step 3, image 1 of 2 Bose SoundLink Color Speaker Replacement: step 3, image 2 of 2
      • Carefully open up the casing.
      • The top button pad may need to be re-glued upon installing the new casing.
      Ask FixBot
    1. Bose SoundLink Color Speaker Replacement, Speaker: step 4, image 1 of 2 Bose SoundLink Color Speaker Replacement, Speaker: step 4, image 2 of 2
      • Lift up the retaining flap on the button cable ZIF connector.
      • Pull the button cable straight out of the connector.
      • Remove the inner assembly.
      Ask FixBot
    2. Bose SoundLink Color Speaker Replacement: step 5, image 1 of 1
      • The speakers are on the front of the inner assembly.
      • Using the Phillips head screwdriver, unscrew the four 1.3 cm screws holding the speaker that will be replaced.
      Ask FixBot
    3. Bose SoundLink Color Speaker Replacement: step 6, image 1 of 2 Bose SoundLink Color Speaker Replacement: step 6, image 2 of 2
      • Three screws hold the printed circuit board.
      • Using the Phillips head screwdriver, unscrew the three 1.2 cm screws.
      Ask FixBot
    4. Bose SoundLink Color Speaker Replacement: step 7, image 1 of 2 Bose SoundLink Color Speaker Replacement: step 7, image 2 of 2
      • Desolder each the three pins connecting the speaker to the motherboard.
      • Carefully lift the motherboard with a spudger to ensure that each pin desolders.
      • Work carefully. Prying too hard may cause damage to the board.
      Ask FixBot
    5. Bose SoundLink Color Speaker Replacement: step 8, image 1 of 1
      • Push the speaker through the front of the inner assembly.
      Ask FixBot
21 other people completed this guide.
13 Guide Comments
Thanks for this tear down. Never thought that it looks like this on the inside. My battery is kind off aging, bought the unit 7 months ago. Local Bose dealer said battery cost half of this speaker. I hope there is a cheaper alternative.
vintiglao22 - Reply Share
You can unsolder the battery and replace with a standard unprotected 18650 cell it literally costs 7$ for a high quality sony or panasonic or samsung cell. The protection and charging circuit is included in the speaker motherboard just make sure you resolder with the proper polarity.
swiftink - Reply Share
Como ago para traducir cada
luis beltran - Reply Share
Speaker looks like a 18650 lithium ion- from the pictures here.
DR Paquette - Reply Share
Does anybody know where one could order a spare speaker for this device?
sebastiansebisilva - Reply Share
Past 24 Hours: 5
Past 7 Days: 49
Past 30 Days: 246
All Time: 36,526
