Up to 20% off select tools
Bose SoundLink Color II Battery Replacement
Views: 36K
View statistics:
Past 24 Hours:
32
Past 7 Days:
164
Past 30 Days:
769
All Time:
36,469
Comments: 19
11 comments on steps, 8 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Community-Contributed Guide
Introduction
Go to step 1 ↓
Like any device with a battery, the Bose SoundLink Color II will need a battery replacement once the battery no longer has the expected capacity.
However, because this speaker is waterproof, this task is not straightforward.
The following steps will guide you through the process of replacing the battery.
Keep in mind that waterproofness cannot be guaranteed once your device has been disassembled, but it is better than replacing the whole speaker, no?
    1. Bose SoundLink Color II Battery Replacement, Battery: step 1, image 1 of 1
      • Start by pulling on the outer edges of the rubber part on the bottom of the enclosure.
      • Note that it will not detach completely from the enclosure.
      Ask FixBot
    2. Bose SoundLink Color II Battery Replacement: step 2, image 1 of 2 Bose SoundLink Color II Battery Replacement: step 2, image 2 of 2
      • Pry between the black hard plastic base and the colored rubber casing of your speaker.
      • The bottom of the speaker unclips, and you have access to the rings that hold the colored envelope.
      Ask FixBot
    3. Bose SoundLink Color II Battery Replacement: step 3, image 1 of 1
      • Pull on the colored envelope, folding it on itself outwards.
      • By removing the cover, the protective foam of the microphone will be damaged, the water resistance will be impacted.
      Ask FixBot
    4. Bose SoundLink Color II Battery Replacement: step 4, image 1 of 2 Bose SoundLink Color II Battery Replacement: step 4, image 2 of 2
      • Remove the 7 screws on the back of the enclosure.
      • And you access the interior of the enclosure (the battery has already been replaced in the photo shown).
      Ask FixBot
    5. Bose SoundLink Color II Battery Replacement: step 5, image 1 of 1
      • Cleanly cut the foam and battery wrap.
      • The foam and the envelope will be used for reassembly (to avoid vibrations).
      • Be careful not to puncture the battery or it may catch fire.
      Ask FixBot
    6. Bose SoundLink Color II Battery Replacement: step 6, image 1 of 1
      • Unsolder the two legs of the battery and take out the battery.
      Ask FixBot
    7. Bose SoundLink Color II Battery Replacement: step 7, image 1 of 1
      • Solder the new battery, and replace the envelope with the foam, holding everything with tape.
      • For reassembly, follow this guide in reverse order.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
12 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
yellowjellyfish
761 Reputation
2 Guides authored
8 Guide Comments
Please be advised that the Bose support website has a firmware update that fixes some battery issues. I took my dead - non-charging Soundlink Color II apart and then found the website and fixed the issue with the firmware update! The update website is located @ http://btu.bose.com
paul ramirez - Reply Share
Beware that, after the battery gets undervolted (like 2.4V), the device does not seem to accept an externally charged battery and continues to act dead, until it finds some form of comfort over its USB input. Not from a dumb 5V power supply, but from an USB charger or PC supporting some level of power delivery extension, and an appropriately wired lead.
Stein Somers - Reply Share
Please list type of battery and where to find it it took me a while to find it
Bootyclapper69 - Reply Share
Guide was good, the battery pcb i found in my unit was a bit different and had metal strips soldered to the board and welded to the battery.
Seifeldin Hashem - Reply Share
How to disassemble the motherboard as I have to change the microusb which got bend pin
Dipro Sarkar - Reply Share
Past 24 Hours: 32
Past 7 Days: 164
Past 30 Days: 769
All Time: 36,469
