Up to 20% off select tools
Bose SoundLink Color Button Pad Replacement
Views: 12K
View statistics:
Past 24 Hours:
7
Past 7 Days:
40
Past 30 Days:
150
All Time:
11,979
Comments: 48
45 comments on steps, 3 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Difficult
Parts
Tools
Introduction
Go to step 1 ↓
When one or all of the buttons stop working on a device, it can be a frightening thing. Use this guide to help.
    1. Bose SoundLink Color  Button Pad Replacement, Outer Casing: step 1, image 1 of 2 Bose SoundLink Color  Button Pad Replacement, Outer Casing: step 1, image 2 of 2
      • Four round, plastic plugs are located on the back of the device.
      • Using a metal spudger, carefully pry up the plastic covers.
      • The covers are all glued on, so be careful not to scar the casing when prying them off. If possible, use a spudger or plastic opening tool to remove them.
      Ask FixBot
    2. Bose SoundLink Color  Button Pad Replacement: step 2, image 1 of 2 Bose SoundLink Color  Button Pad Replacement: step 2, image 2 of 2
      • Remove the four 1.8 cm-long T15 Torx Security screws from the outer case.
      • Some of these use T15 "Star" 5-point Torx security screws instead of the more common 6-point ones.
      Ask FixBot
    3. Bose SoundLink Color  Button Pad Replacement: step 3, image 1 of 2 Bose SoundLink Color  Button Pad Replacement: step 3, image 2 of 2
      • Carefully open up the casing.
      • The top button pad may need to be re-glued upon installing the new casing.
      Ask FixBot
    1. Bose SoundLink Color  Button Pad Replacement, Button Pad: step 4, image 1 of 2 Bose SoundLink Color  Button Pad Replacement, Button Pad: step 4, image 2 of 2
      • Lift up the retaining flap on the button cable ZIF connector.
      • Pull the button cable straight out of the connector.
      Ask FixBot
    2. Bose SoundLink Color  Button Pad Replacement: step 5, image 1 of 2 Bose SoundLink Color  Button Pad Replacement: step 5, image 2 of 2
      • Carefully pull the ribbon cable through the rubber gasket that runs around the device.
      Ask FixBot
    3. Bose SoundLink Color  Button Pad Replacement: step 6, image 1 of 1
      • To remove the old rubber button pad, carefully peel it off of the blue casing.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order, starting from Step 6.
8 other people completed this guide.
Author
with
Michael Thorn
557 Reputation
3 Guides authored
3 Guide Comments
Great guide, and I think I can manage this. But, where can I get the Replacement Bose SoundLink Color Button Pad??
Fred
Fred Fish - Reply Share
I’m wondering the same thing. Where do you get the replacement Bose Soundlink Color button pad? We just bought a new charger because we thought that was the problem. But that didn’t make any difference. We still can’t turn the speaker on!
Lynn Wilson - Reply Share
I got the bose soundlink color button panel only with bose India authorised service center in South Mumbai . That cost me in Indian RS. 2360. Including approx $35 USD.
nrirehan - Reply Share
Past 24 Hours: 7
Past 7 Days: 40
Past 30 Days: 150
All Time: 11,979
