Bose SoundDock Portable v2 Speaker Replacement
    1. Bose SoundDock Portable v2 Speaker Replacement, Speaker: step 1, image 1 of 3 Bose SoundDock Portable v2 Speaker Replacement, Speaker: step 1, image 2 of 3 Bose SoundDock Portable v2 Speaker Replacement, Speaker: step 1, image 3 of 3
      • Gently pry the front mesh cover off of the SoundDock using a metal spudger.
      • The mesh is held on by small velcro strips so if you hear a tearing sound it is just the velcro coming apart
      Ask FixBot
    2. Bose SoundDock Portable v2 Speaker Replacement: step 2, image 1 of 2 Bose SoundDock Portable v2 Speaker Replacement: step 2, image 2 of 2
      • Remove the four 16mm #2 screws holding the speaker to the base using a #2 screwdriver
      • Gently lift the speaker from the base.
      • Do not lift the speaker to far out of the base, you may damage the wires.
      Ask FixBot
    3. Bose SoundDock Portable v2 Speaker Replacement: step 3, image 1 of 1
      • You will notice 2 coils of wire around the speaker's input tabs. Slide these coils off as un-winding the wires may break the wires. Slide the coils around your new driver.
      Ask FixBot
6 other people completed this guide.
Evan Low
584 Reputation
4 Guides authored
Cal Poly, Team 4-1, Maness Spring 2015 Member of Cal Poly, Team 4-1, Maness Spring 2015
CPSU-MANESS-S15S4G1
4 Members
60 Guides authored
5 Guide Comments
I am unsure of what to do in step #3…
Is the purpose to remove the speaker completely and place a brand new one? (Making sure not to pull the old speaker too far out as to not break any wire… ) ???
Edited comment:
I am not sure what they mean by "pins".
vero198099 - Reply Share
Hi I just accidently pushed in that dome part in the middle a little and now it distorts. I tried using a vacuum but it didnt work. Please help!!!!!!!!
AJ Grape - Reply Share
Try to see if there’s any way you can reduce the nozzle size of the vacuum cleaner you’re using - this should increase the flow rate, and possibly the amount of force applied over such a small area.
Alternatively, you can use a very very fine needle, bend the end of it, and use it to “hook” the cone. This method is really a last resort, as you want to avoid making even the smallest of holes.
Absolute last resort is replacing the speaker, which if you can find a replacement, should be pretty easy.
Colm Donnelly - Reply Share
Need help love this speaker when it’s played loud it makes a load noise when the base is on changed aux lead think it’s the speaker what do I do
Chantelle Webb - Reply Share
How do you cut on without remote
Chad Davenport - Reply Share
Past 24 Hours: 5
Past 7 Days: 36
Past 30 Days: 130
All Time: 13,094
