Bose SoundDock Portable v2 IR Receiver Replacement
    1. Bose SoundDock Portable v2 IR Receiver Replacement, IR Receiver: step 1, image 1 of 3 Bose SoundDock Portable v2 IR Receiver Replacement, IR Receiver: step 1, image 2 of 3 Bose SoundDock Portable v2 IR Receiver Replacement, IR Receiver: step 1, image 3 of 3
      • Gently pry the front mesh cover off of the sound dock using a metal spudger.
      • The mesh is held on by small velcro strips so if you hear a tearing sound it is just the velcro coming apart.
      Ask FixBot
    2. Bose SoundDock Portable v2 IR Receiver Replacement: step 2, image 1 of 1
      • Using a T15 torx screwdriver, remove the 8mm screw holding the IR sensor to the speaker system.
      Ask FixBot
    3. Bose SoundDock Portable v2 IR Receiver Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Using tweezers or your fingers, gently remove the ribbon cable connecting the IR sensor to the system.
      Ask FixBot
3 other people completed this guide.
Evan Low
584 Reputation
4 Guides authored
Cal Poly, Team 4-1, Maness Spring 2015 Member of Cal Poly, Team 4-1, Maness Spring 2015
CPSU-MANESS-S15S4G1
4 Members
60 Guides authored
1 Guide Comment
Hi my sounddock blocked suddenly and the green led always on. Do you now something about please... :(
jose - Reply Share
Past 24 Hours: 2
Past 7 Days: 31
Past 30 Days: 70
All Time: 7,798
