This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Bose Solo 5 Power IC Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
28
Past 30 Days:
138
All Time:
393
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Community-Contributed Guide
Introduction
Go to step 1 ↓
If your Bose Solo 5 no longer turns on, follow this short guide. 99% of the time, you need to replace the same integrated circuit I did.
Tools
    1. Bose Solo 5 Power IC Replacement, Open the part where the connections are: step 1, image 1 of 1
      • Unscrew the 5 Phillips screws
      Ask FixBot
    2. Bose Solo 5 Power IC Replacement, Remove the board: step 2, image 1 of 1
      • Remove the antenna wire and gently lift the electronic board by prying from the area opposite the connectors.
      • Do not lift it too high, there is wiring with a connector underneath.
      Ask FixBot
    3. Bose Solo 5 Power IC Replacement, Remove the board: step 3, image 1 of 1
      • Disconnect the connector and remove the board.
      Ask FixBot
    4. Bose Solo 5 Power IC Replacement, Remove the integrated circuit: step 4, image 1 of 2 Bose Solo 5 Power IC Replacement, Remove the integrated circuit: step 4, image 2 of 2
      • Rotate the board 180° and locate this integrated circuit; it is the cause of the failure. Desolder it and replace it with a new one.
      Ask FixBot
    5. Bose Solo 5 Power IC Replacement, Reassembly: step 5, image 1 of 1
      • Follow these instructions in reverse order to reassemble your device.
      Ask FixBot
andreacero
695 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 138
All Time: 393
