Introduction
This guide aims to provide a step-by-step process to replace an earcup, the earcup provides more insulation and helps with isolating sound in the headphones.
Tool used on this step:Tweezers$4.99
After removing the cushion you should be exposing the cloth, carefully remove the glued part with tweezers and place your new one.
After removing the cloth you will expose a plastic plate with three 4 mm screws.
Grab your PH00 head and unscrew them.
2 other people completed this guide.
