Bose QuietComfort 15 Battery Replacement
    1. Bose QuietComfort 15 Battery Replacement, Battery Replacement: step 1, image 1 of 1
      • Hold the headphones with the earcups facing you.
      • Locate the battery compartment on the inside of the right earcup.
      • The battery compartment is a small rectangular door that holds the AAA battery used for noise cancellation.
      Ask FixBot
    2. Bose QuietComfort 15 Battery Replacement: step 2, image 1 of 3 Bose QuietComfort 15 Battery Replacement: step 2, image 2 of 3 Bose QuietComfort 15 Battery Replacement: step 2, image 3 of 3
      • Slide the battery compartment door open using your finger.
      • Remove the old AAA battery from the compartment.
      • Do not use excessive force when opening the battery compartment.
      • If the battery does not come out easily, tilt the headphones or gently tap the earcup to loosen it.
      Ask FixBot
    3. Bose QuietComfort 15 Battery Replacement: step 3, image 1 of 3 Bose QuietComfort 15 Battery Replacement: step 3, image 2 of 3 Bose QuietComfort 15 Battery Replacement: step 3, image 3 of 3
      • Insert a new AAA battery into the battery compartment.
      • Close the battery compartment door until it clicks into place.
      • Insert the battery with the positive (+) end facing inward.
      • Once installed, the headphones should have power and noise cancellation should function normally.
      Ask FixBot
Brayden Webb
512 Reputation
4 Guides authored
Texas Tech, Team 41-5, Johansen Spring 2026 Member of Texas Tech, Team 41-5, Johansen Spring 2026
TTU-JOHANSEN-S26S41G5
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 124
All Time: 352
