Bose Frames Alto Battery Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
10
Past 7 Days:
47
Past 30 Days:
318
All Time:
2,536
Comments: 2
2 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Short battery life? Replace it to restore your playtime!
Note: This guide requires delicate soldering on small wires.
Parts
Tools
    1. Bose Frames Alto Battery Replacement, Soften the Adhesive: step 1, image 1 of 1
      • Heat the left earpiece for three minutes on high with a hair dryer to soften the adhesive holding the cover. An iOpener or a heat gun on low heat can also be used.
      Ask FixBot
    2. Bose Frames Alto Battery Replacement, Remove the Cover: step 2, image 1 of 2 Bose Frames Alto Battery Replacement, Remove the Cover: step 2, image 2 of 2
      • Insert a flat blade screwdriver between the hinge and the cover.
      • Use the hinge as a fulcrum to lever up the cover.
      Ask FixBot
    3. Bose Frames Alto Battery Replacement: step 3, image 1 of 3 Bose Frames Alto Battery Replacement: step 3, image 2 of 3 Bose Frames Alto Battery Replacement: step 3, image 3 of 3
      • Insert an opening pick next to the hinge.
      • Slice the adhesive along the edge of the cover.
      • There is an internal protrusion at this point that will stop your pick.
      • Repeat for the opposite side.
      Ask FixBot
    4. Bose Frames Alto Battery Replacement: step 4, image 1 of 2 Bose Frames Alto Battery Replacement: step 4, image 2 of 2
      • Remove the cover.
      • Clean the old adhesive from the earpiece and the cover.
      Ask FixBot
    5. Bose Frames Alto Battery Replacement, Remove the Battery: step 5, image 1 of 2 Bose Frames Alto Battery Replacement, Remove the Battery: step 5, image 2 of 2
      • The battery is lightly adhered to the earpiece with double sided tape on the end next to the hinge. Pry it up with an opening pick.
      • Turn the battery over and fold it out of the way.
      Ask FixBot
    6. Bose Frames Alto Battery Replacement: step 6, image 1 of 1
      • Note the positions of the wires in case your replacement battery doesn't use the same colors.
      • Yellow is the battery positive terminal (+)
      • White goes to the BMS board
      • Red is the speaker positive wire (+)
      • Black is the speaker negative wire (-)
      • Blue is battery negative (-)
      Ask FixBot
    1. Bose Frames Alto Battery Replacement, Battery: step 7, image 1 of 3 Bose Frames Alto Battery Replacement, Battery: step 7, image 2 of 3 Bose Frames Alto Battery Replacement, Battery: step 7, image 3 of 3
      • Grasp the blue wire with tweezers then remove it with your soldering iron.
      • Repeat for the yellow wire.
      • And finally the white wire.
      Ask FixBot
    2. Bose Frames Alto Battery Replacement: step 8, image 1 of 1
      • The battery has been removed.
      • For reassembly, add a piece of double sided tape to the end of the replacement battery next to the hinge.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order, gluing down the cover as the last step.
3 other people completed this guide.
Jerry Wheeler
102,196 Reputation
92 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 47
Past 30 Days: 318
All Time: 2,536
