Bose Cinemate 10 Subwoofer Replacement
  1. Bose Cinemate 10 Subwoofer Replacement, End Cap: step 1, image 1 of 2 Bose Cinemate 10 Subwoofer Replacement, End Cap: step 1, image 2 of 2
    • Using the blue plastic opening tool, pry up on the cloth covered end panel. The edge of end cap cover should separate from main body of device.
    Ask FixBot
  2. Bose Cinemate 10 Subwoofer Replacement: step 2, image 1 of 1
    • Using your fingers, lift up on the end cap cover until it separates completely from the main body of the device.
    Ask FixBot
  3. Bose Cinemate 10 Subwoofer Replacement: step 3, image 1 of 2 Bose Cinemate 10 Subwoofer Replacement: step 3, image 2 of 2
    • Remove the 4, PH1, 15mm screws on the side speaker cover frame.
    Ask FixBot
  4. Bose Cinemate 10 Subwoofer Replacement: step 4, image 1 of 1
    • Remove speaker cover frame from main body of device.
    Ask FixBot
  5. Bose Cinemate 10 Subwoofer Replacement, Subwoofer: step 5, image 1 of 2 Bose Cinemate 10 Subwoofer Replacement, Subwoofer: step 5, image 2 of 2
    • Remove the 4, PH1, 10 mm screws from the subwoofer frame.
    Ask FixBot
  6. Bose Cinemate 10 Subwoofer Replacement: step 6, image 1 of 2 Bose Cinemate 10 Subwoofer Replacement: step 6, image 2 of 2
    • Using the blue plastic opening tool, pry up on the edge of the subwoofer frame.
    • Using your fingers, lift up on the subwoofer frame until it separates completely from the main body of the device.
    Ask FixBot
  7. Bose Cinemate 10 Subwoofer Replacement: step 7, image 1 of 3 Bose Cinemate 10 Subwoofer Replacement: step 7, image 2 of 3 Bose Cinemate 10 Subwoofer Replacement: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Using the curved precision tweezers, grasp end of wire.
    • Using the curved precision tweezers, unravel wire around blue metal post.
    Ask FixBot
  8. Bose Cinemate 10 Subwoofer Replacement: step 8, image 1 of 2 Bose Cinemate 10 Subwoofer Replacement: step 8, image 2 of 2
    • After wire is completely unraveled, repeat steps 4 and 5, on red metal post.
    • Remove the speaker from the device.
    Ask FixBot
1 Guide Comment
Where can I buy the speaker to replace?
Zeroni Santos - Reply Share
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 51
All Time: 1,962
