Bose Ae2w 2.5 Audio Jack Replacement
  1. Bose Ae2w 2.5 Audio Jack Replacement, Earpiece Cushion: step 1, image 1 of 2 Bose Ae2w 2.5 Audio Jack Replacement, Earpiece Cushion: step 1, image 2 of 2
    • Carefully pull the cushions away from the sides of the headphones, sliding the cushions out from under the notches.
    Ask FixBot
  2. Bose Ae2w 2.5 Audio Jack Replacement: step 2, image 1 of 1
    • Carefully wipe the inside of the earpiece clean. This can be done with a moistened cotton swab or alcohol wipes.
    Ask FixBot
  3. Bose Ae2w 2.5 Audio Jack Replacement, Speaker Mesh: step 3, image 1 of 2 Bose Ae2w 2.5 Audio Jack Replacement, Speaker Mesh: step 3, image 2 of 2
    • Using a spudger or tweezers, carefully lift the speaker mesh from around the edge.
    • The mesh is typically glued down, go slowly to avoid tearing or damaging the speaker beneath.
    • Cut your new mesh slightly larger than the opening so it can be anchored around the edges.
    Ask FixBot
  4. Bose Ae2w 2.5 Audio Jack Replacement: step 4, image 1 of 2 Bose Ae2w 2.5 Audio Jack Replacement: step 4, image 2 of 2
    • Scrape off any gunk or adhesive left over on the ear cups.
    • Use a moist cotton swab or alcohol wipe to ensure the surface is completely cleaned and ready for new adhesive.
    Ask FixBot
  5. Bose Ae2w 2.5 Audio Jack Replacement: step 5, image 1 of 1
    • Use a thin layer of fabric glue or double-sided tape around the perimeter of the speaker housing.
    Ask FixBot
  6. Bose Ae2w 2.5 Audio Jack Replacement: step 6, image 1 of 1
    • Gently place the new mesh over the speaker opening, pressing it down onto the adhesive.
    • Wait for adhesive to dry if applicable.
    Ask FixBot
  7. Bose Ae2w 2.5 Audio Jack Replacement, 2.5 Audio Jack: step 7, image 1 of 2 Bose Ae2w 2.5 Audio Jack Replacement, 2.5 Audio Jack: step 7, image 2 of 2
    • Once the cushion and mesh are removed, remove the three screws in the earpiece.
    Ask FixBot
  8. Bose Ae2w 2.5 Audio Jack Replacement: step 8, image 1 of 2 Bose Ae2w 2.5 Audio Jack Replacement: step 8, image 2 of 2
    • Gently separate the earpiece to access the audio jack.
    • Remove the two screws holding it in place.
    • Lift and remove the audio jack assembly.
    Ask FixBot
  9. Bose Ae2w 2.5 Audio Jack Replacement: step 9, image 1 of 2 Bose Ae2w 2.5 Audio Jack Replacement: step 9, image 2 of 2
    • Identify all solder connections on the audio jack circuit board.
    • Using your soldering iron, carefully desolder each wire from the circuit board.
    • Take care not to damage any of the wires, as they must be soldered onto the new replacement audio jack circuit board.
    Ask FixBot
Ben Ponte
509 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 43
All Time: 340
